noise when shifting from OD to Drive
My truck makes a noise that kinda sounds like i run over a rumble strip on side of the road when truck shifts down from OD to Drive.. only last for a second, sounds like it coming from under truck and not steering or wheel area... ANY IDEAS? Plan on taking truck to tranny shop to see if that is it but wondering if anyone on here has similar problem or knows what it is....
HAPPY THANKSGIVING!!!
I have had exactly the same issue, but for some reason, it's gone away recently. If you read the forum here, you'll find a few different possible reasons - one is a misfire caused by a bad or weak coil. Others have replaced the transmission fluid with good success - changing to Mercon V fluid is supposed to help.
Try searching for more details. Good luck!
I've had the bad coil problem...mine turned out to be cylinder #1. I've also had the plugs replaced where the shop managed to break 4 of the 8. It's definitely a different sensation when you've clearly felt them both. The plug/coil is more of a sputter/bucking feeling. This feels EXACTLY like passing over a small rumble strip. Like one you might hit when entering a slow-down zone on a freeway, except it only happens when downshifting from OD to Drive as ttw mentioned.
lincolnboy73
1997-2006 Expedition & Navigator
13
08-17-2012 04:41 PM
mwkobe
09-27-2011 07:43 PM
landolakes
1999 to 2016 Super Duty
01-10-2004 09:33 PM
