Boost source for gauge
Old Nov 22, 2011 | 09:43 PM
AZbluewhale's Avatar
AZbluewhale
Looking for the easiest place to tap into the boost for an aftermarket gauge installation.
Roy
Old Nov 22, 2011 | 11:03 PM
Big Red 5205's Avatar
Big Red 5205
Remove the intake elbow from the top of the intake manifold, just a CAC hose clamp, couple of bolts and it's off. It has a reusable o-ring under it. It's alluminum so it's easy to drill and tap. With it off the engine, it's easier to work on and no chance of alluminum chips entering engine during work.
Old Nov 23, 2011 | 09:54 AM
dchamberlain's Avatar
dchamberlain
The easiest place is to cut into the MAP sensor hose and put a T in it. The MAP sensor is on a bracket at the passenger side rear of the engine. The hose runs from the sensor to the intake manifold.
Old Nov 23, 2011 | 10:38 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Intake elbow gets my vote. Easy to drill/tap
Old Nov 23, 2011 | 11:08 AM
j4henry's Avatar
j4henry
Tis where I put mine. ^^^^^
Old Nov 23, 2011 | 11:19 AM
BLADE35's Avatar
BLADE35
I kinda like this spot David Mentioned
ford4lifer
Nov 16, 2006 08:57 AM
watermanh
Aug 30, 2005 11:29 AM
welder2000
Oct 29, 2004 01:34 PM
Monster Duty
Sep 12, 2004 10:42 PM
Jozey
Sep 28, 2003 12:26 PM
