I have an 89 f150 4.9L dual tank, the truck has been dead(battery) for days got it charged and there is a click then a hum. Key is out of the truck but doesn't stop. Saw the fuel line jumping but don't understand why the pump would run with key off. Plus I go to start it and it turns over but will not start. Please help
Something I noticed was I smell gas after I try to start it and the fuel pump stays running with key on. I can sometimes get it to start but putt putts and dies after like 10 sec
The spark plugs are probably fouled with fuel.Change them. Change the relay, like you were told in the begining of the thread, so it stops running with the key off.
I did replace the relay and it stopped running with the hey off . But its running nonstop with the key on.
Engine not running? If so adding to that your other comments "Something I noticed was I smell gas after I try to start it and the fuel pump stays running with key on. I can sometimes get it to start but putt putts and dies after like 10 sec" sounds like your computer might be the issue.
Check the computer ground connection that goes straight to the negative battery cable. If that is not making good connection, it will act just like you are saying when trying to start. Will crank and give spark, but won't get enough fuel to fire off.
