the gutless wonder
the gutless wonder
I just picked up an 86 f350 4x4 crew cab with a 6.9l and 4 speed trans. drove it two hours home without a problem besides the fact i was pretty much floored the whole way home and barely kept up at 55-60 mph.
im not sure how many miles are on it its says 96k which it maybe as it was used as a ranch truck and the motor looks untouched. ive searched and it looks like a new injection pump and injectors will make a difference. What else are some known problems i should be looking for?
oh and heres a pic of when i brought it home and after with a coat of primer.
So you've got a 86 crewcab 4x4 diesel that looks amazing. I am jealous. I wanted one but ended up settling for an extended cab. I guess I am happy with the extended cab though because even it is almost to long to drive in small parking lots.
I have a 85 NA 6.9 4x4 that will absolutely bury the speedo needle and thats with a C6 and 3.55s. In fact, I do it all the time, sometimes everyday. So, don't give up on it!
well i changed the fuel filter today it seems to start better when its cold. the air filter is clean and it still has the tiny factory exhaust. i drove it around it still feels the same. Its kinda hard to explain but when i rev it up it seems like its surging, missing. Anyone know what could be causing this?
on
sounds like it could be injectors too of course.
the ip and injectors are medium ware items and typically go for 100k miles at peak performance.
a complete idi tune up is a good place to start,after making sure her compression is still healthy if you plan to have the truck for a while,which looks like you do,based on the body work done.
making sure you don't have a weak/failing lift pump is a good place to investigate when she seems to be lacking power/struggling to run good too.
brandon_oma#692
64
11-29-2017 10:26 AM
shakenbake254
13
01-06-2016 03:32 PM
BlueOvalDismantlers
S. California Chapter
08-30-2012 05:31 AM
