Timing BTC degree?
Old Nov 21, 2011 | 07:41 PM
charleswood6969's Avatar
charleswood6969
Timing BTC degree?
Well, I broke down and ordered a Ferret V765-01 pulse adapter. Can't seem to get it close to right by ear. So, searched thru the forums trying to find the answer....close, but no cigar....anybody know off the top of their head at what rpm the 8 degree BTC is at? I am thinking it is 8 BTC at 2000 rpms......
The way it's acting, I am thinking I have some dribbling injectors, cause the pump is a new rebuild, but I'm getting unburned fuel and lots of blue smoke. Rough running at the top rpm at high idle, plus galloping at low idle after a few minutes.
The good side is, the lower end must be great, because cold idle, the oil pressure is 35, and warm idle 25.
Old Nov 21, 2011 | 08:18 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
8.5* BTDC @2000rpm
chances are the new(reman) IP is showing the age of the injectors and that is giving you your smoke and and rough running. when i had 4 bad injectors i could easily smoke out the entire road behind me. it also sounded like a rod was about to be launched threw the block.
Old Nov 21, 2011 | 10:04 PM
charleswood6969
Thank you 94IDITurbo7.3 Thar's kinda what I remembered. Almost got the old gal runnin' again.
Thanks.
Old Nov 22, 2011 | 06:36 AM
NorthernDiesel's Avatar
NorthernDiesel
The Ford book says it like this:
I run closer to 9 degrees advance, it was still a little smoky when cold at 8. I do have the pump tuned up a lot though, I'm not sure how much that plays in.
Old Nov 22, 2011 | 06:47 AM
charleswood6969
Pump was rebuilt by the local Stanadyne dealer, Des Moines Diesel. I assume they took it back to factory specs, and it's a 6.9 N/A. I didn't ask them to turn it up, anyway. Probably bad injectors. I know I have two that I had to put in that were out of my old engine temporarily, that had 140,000 miles on them. The others have an unknown number of miles. I plan to get the pump close to 8 degrees BTDC, and see what the injectors do from there.
Thanks guys!
LordKamakazi
May 5, 2016 11:51 PM
jr_vw2
Jul 9, 2012 04:45 PM
dentsideranger
13
Apr 18, 2012 07:25 PM
rmalottwtes30
15
Jul 8, 2011 05:29 PM
anothersteveg
Sep 22, 2007 06:28 AM
