PO500 vss confusion
PO500 vss confusion
I have searched but couldn't find someone with my configuration and a vss problem. I have a 2001 F150 4x4, 4.6L 5 speed, manual transfer case. I have experience with Rangers and know that they use the abs sensor on the rear axle for the vss. From what I have read the vss on my F150 is on the rear of the transfer case. I picked up a sensor from autozone and they sold me the one with the speedo gear. I haven't pulled mine yet but I think the gear driven sensors are for 2wd trucks. Does this sound correct? Also do I actually need an OSS instead of a Vss even though the code reader says a vss error PO500?
Btw the speedo doesn't work and the odometer quits after the truck is driven a short distance.
TIA
John
TIA
John
workingdog
06-13-2006 11:34 PM
