water/fuel seperator drain location
When you find it. which will be shortly. get your self one of these:
DTS Articles - HFCM Water Separator Drain Plug Upgrade
By the picture, you can see where on the lower filter (HFCM) the drain is located.I think it is a 6mm hex plug. They tend to strip.
Look on your fuel pump/water separator thats mounted in the frame rail in the area of the drivers side door. You will see a plug with a 6mm allen hole in the plug, remove the plug and drain. If the WIF light still keeps coming on and you are satisfied there is no water in what your draining, then the sensor is sludged up giving you false readings.
Good resource for information like this is in the tech-folder at the top of the thread page.
https://www.ford-trucks.com/forums/3...ch-folder.html
Here is a good how to from there:
http://www.dieselfiltersonline.com/D...ence-Guide.pdf
Rick Braden
09-07-2004 08:10 PM
