The pump is about the only useful part off an SD, everything else has to be sourced aftermarket. Make sure to get the bracket and wiring pigtail, with about 4" of the truck side harness if possible.
Thanks for the link King. The guy hasn't called me back yet so may not happen. I guess if it does, I will try to get everything I can. Is there any inertia safety switches or other things like that also?
So what aftermarket parts are needed? Pressure regulator?
Pressure regulator
Some way to split the feed line to feed both rear heads
Plug for the mech. pump hole in the block
Pre pump filter/head (30micron)
Post pump filter/head (2 micron)
Fuel hoses and fittings
Wiring
