CCV delete instructions?
1duallyman has supplied the intructions and if you aren't going to DIY here is a link to Riffraff CCV Mod Kit.
Thanks!
I don't think I have enough posts to get access to PM's just yet (unless I missed the option).
I read an article from Blackstone that said a closed loop CCV system (such as the OEM Power Stroke) is better for the engine oil compared to a system that is open to the atmosphere (such as the OEM International T444E). They believe there is less oil contamination due to condensation with a closed CCV system and had some data to back up the theory.
We have several of both kinds of systems on our fleet trucks, looking at the oil sample reports I can not tell any difference between the two different systems.
If it gets cold where you live then you want to take care that you route the hose is such a way so moisture doesn't get trapped and freeze.
You can try it and see if you like it better...just keep your original parts in case you want to revert back. I know a guy who did the mod but neglected to plug the hole in the bottom of the intake tube and it ruined his engine. I think the CCV mod is associated with those who go with a 6637 filter and delete the intake tube spacer piece. Unfortunately the guy didn't know about that little detail...
If you route the line straight down into the wheel well, there shouldn't be any freezing issues. Lots of folks in cold areas have done it. The engine heat keeps anything from freezing.
Like S&B said, keep all the parts and do not permanently seal the hole where the CCV goes into the turbo tube. Maybe later on you'll want to do a permanent change and plug it.
Well, I didn't mean to, really I didn't, but I did the CCV mod today. I was just aiming to check the glow plugs on the drivers side, but to get to the harness, I had to take the connecting sleeves off (does everyone?). Since I had it off and didn't want to have to fight with the elbow to get it back on, I flipped the doghouse and bought the hose.
The only thing, Advance Auto didn't have the o-rings for the doghouse. The old ones were pretty well mashed and fit neither the recess on the doghouse nor the opening on the valve cover. I had to put it back together anyway, just lined them up as best I could. Got it all back together and ran it for 15 minutes, didn't see any obvious leaks.
I didn't terminate it into a trap yet, that'll have to wait until tomorrow.
My plan was to terminate just ahead of the fuel tank on the drivers side. Is that acceptable?
Also, is it imperative that there is never any rise to the hose? the reason I ask is I would like to mount it a bit higher than the bottom of the frame and I have the hose running along the inside/bottom frame rail.
Thanks for your thoughts.
