Anyone using 285/75 tires and having speed sensor errors? I'm looking to go from the stock 265/75 R16 to wider-width tires and curious if the larger wheel diameter and less tire revolutions would set off a computer code due to the ABS speed sensors
Same here. Running 285/75 with no problems. Speedo is off by about 3% but you can get that adjusted at dealer or with a programmer. My dealer did it for free. Only took him about 20min.
