Do it yourself. Save a lot of money. Cost me about $80 for oil/filter. Just make sure you have a big OPEN drain pan, not one with the small drain hole in the center.
I just did the last one myself. Very easy with all the room under there. Will be doing the fuel filters also next time.
Had the fuel filters done at the same time for $179.95. I'm going to go the dealer route until all this fuel pump issues are resolved. "Hey, you touched it last"!
Mine was 59.95 but the dealer overfilled it by 2qrts and had to go back and let them fix it. Plus they only had been using the water test kit and didnt even know about the contamination kit until yesterday for the coolant.
$107 with taxes so around $97 for oil and filter at my dealer.
I change the oil/filter myself for less than $30 usually because I have $50 autozone gift cards laying around for this purpose.
(Discover card reward points that I'm accruing regardless.)
All it takes is a bit of my time.
