i need a 3amp fuse for my gauge cluster lights but nobody has the right length fuse. i checked EVERY possible place in my area and nobody had one. anybody know where i could get one?
my kickdown is unhooked down where it connects to the tranny. i can get it put on but what holds it on? is there a clip or something? i cant figure out what holds it on there
i also need a new t-stat sender, where can i find a good one?
Hey! I would say that you can get the fuses through Napa just have them look the fuse up in their books rather than the computer ...they should also be able to get you the temp sending unit.
As for the kickdown i cannot say since i run and have only experience with a standard trannies. hope that helps. If it don't be patient others will chime in as they can.
If Napa can't find the fuse for you in the books, then you can surely get it online. Even Summit carries a broad range of fuses. Worst case, you may have to get it in a multi-pack.
