Dana 60 vs 05+ SD axles
I'm pretty much really comtemplating losing the D50 and going some form of straight axle. I've spent a good deal of time reading in the PSN library about it but my mind is kind of jumbled right now with all the speculation mixed in with the facts. I know the rear disc brakes have to be addressed somehow on the SD setup as well as wheels. Let's just pretend I have each an OBS F350 and an 06 rolling chassis. What would have to be done in each case to swap over? I can obviously unbolt and bolt on but I wanna know about possible fab work, custom fabbing, etc.
Doesnt the 06 have a coil front? I would imagine the rear would be a fairly simply bolt in with a modded drive shaft for the different pinion.
The front if I was gonna swap to the coil would be a 4 link setup. Get rid of any problem that is already known with the hopping. If you go for a direct swap. Just copy the brackets on the 06 frame and bolt in. The fun would be the steering Fab wise.
You may want to look up Cary Towery @ CT Performance. He's done a few of these swaps. I don't think they are too difficult, but some mods & fabrication is needed. He was installing a set in a 97 when I was at his shop... looked pretty darn cool! The ride of a newer SD with the cool looks of an OBS...
It's possible to do coil front with our trucks with LOTS of fabbing.
I'm considering just doing something like starting with a newer frame like an 06 frame and going from there. The frames are SUPER strong, and you'd have a better overall suspension.
Not sure yet though.
To many idea's swimming though my head.
on
Some good reading here, worth it. 06 Axle swap, the whole story - Ford Powerstroke Diesel Forum
The big bonus is much tighter turning radius then the OBS D60 turning radius.
somethingclever
31
10-23-2015 07:10 PM
70crewcab
10-28-2009 01:43 PM
