Lifting 2wd F100? - Ford Truck Enthusiasts Forums
Lifting 2wd F100?
Old 11-12-2011, 08:25 PM
Magic Smoke
Magic Smoke is offline
Magic Smoke is starting off with a positive reputation.
Lifting 2wd F100?
I'm looking to lift the front end of my 70 2wd somewhere around 2-4 inches. I have a set of 265/75/16 tires I'd like to run. I've read that drop brackets used to be available for the beams, but they seem to be off the market now. I can't even find pictures. Does anybody have any info on these, or another inexpensive alternative?
I have found a $1400 kit that will go 5 inches, but that's a bit taller than I'd like and too much money. I've also read that the beams can be flipped over and switched side to side for a 10 inch lift, but that's ridiculous for my needs.
I know I can just throw taller springs in there and it will lift it but the camber will be way off and it will eat the outsides of the tires. The beams could be bent to compensate but I'd rather just drop the mounting point an appropriate amount and be done with it.
Thanks,
Devin
Old 11-12-2011, 09:41 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Do it right or don't do it at all. Thanks.
Here's what ya need: 65-79 econo lift
Looks like fun!!!
Old 11-13-2011, 03:12 PM
351Cleveland C4's Avatar
351Cleveland C4
351Cleveland C4 is online now
351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.351Cleveland C4 has a great reputation on FTE.
you can just go with the taller springs and lower the mounting points on the i beams. jcwhitney has such brackets. i cant remember if they fit bumps though. ill look threw their catalog and tell ya when i find them.
Old 11-13-2011, 03:17 PM
68Ford4Life's Avatar
68Ford4Life
68Ford4Life is offline
68Ford4Life is starting off with a positive reputation.
LMC Truck used to have leveling kits...i think it raised the front 2 inches and lowered the back like 1 or something like that
Old 11-14-2011, 08:33 AM
351Cleveland C4
those brackets are for 80-97 trucks.
but theres no reason (that i know of) why you couldnt do it that way.
if you could build the brackets or if you are able to find them, or have them built.
Old 11-18-2011, 11:35 PM
Magic Smoke
I'm still reading. If i can't find brackets readily available I'll probably go with the posted econo kit. Thanks for the input.
Devin
Old 09-19-2013, 04:31 PM
351Cleveland C4
well now that link doesn't work anymore, silver.
anybody still know a place?
Old 09-19-2013, 04:46 PM
HIO Silver's Avatar
HIO Silver
Oh have some faith! .. please Autofab's website at : Offroad Truck Parts & Car Restoration - Autofab
Old 09-19-2013, 05:07 PM
2FordTrucks
2FordTrucks is offline
2FordTrucks is starting off with a positive reputation.
Those are the same size tire I am running on my stock height 2wd. Gives it a full look but they really are too big.
Old 09-19-2013, 06:38 PM
JEFFFAFA's Avatar
JEFFFAFA
JEFFFAFA is online now
JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.JEFFFAFA has a spectacular reputation.
You might PM BillW and/or Area351. See if they are interested in making them for you.
Old 09-22-2013, 03:56 PM
351Cleveland C4
ive got 31x1050R15s they fit nicely. no rubbing or such. I would just like to lift the front up a few inches to have it sit level. it just looks totally wrong to me seeing a truck going down the road nosed down...
I can build what I need if somebody would be willing to leak their plans to me...
all I need is some brackets to drop the beams and maybe the radius arms...
1500 bucks is WAY to rich for me..
Old 09-22-2013, 04:46 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by 76Hauler View Post
long radius arms and custom brackets
long travle coil buckets
new leaf springs
fun time!
Here's a fellow FTEer with an Autofab 5-inch lift and 33s:
1978 Ford F150 4x2 - Autofab 5
mark460
06-02-2016 03:06 PM
PoreBoy
04-28-2016 08:27 AM
Sayer Lane
52
01-18-2015 03:29 AM
AFSDDude
1999 to 2016 Super Duty
03-08-2014 04:43 PM
79 f-150 guy
01-03-2011 02:36 PM
Quick Reply: Lifting 2wd F100?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
