EGR Valve Won't Budge...
Old 11-12-2011, 07:12 PM
bebeard's Avatar
bebeard
bebeard is offline
hi all,
I'm trying to remove my EGR valve but it won't budge. I have tried the claw to pry it
Is there a special tool I can buy?
thanks,
Old 11-12-2011, 07:56 PM
bismic's Avatar
bismic
bismic is online now
Received 2,449 Likes on 1,696 Posts
Old 11-12-2011, 08:26 PM
XB70's Avatar
XB70
XB70 is offline
If you've tried a crow's foot (claw), grab a pair of Channel Locks and GENTLY grab the body of the valve. Twist it about 20 degrees, then pull straight up.
It does not require much force at all.
(Mark, i think you posted pictures of the hole where the EGR valve resides.)
Old 11-13-2011, 08:17 AM
HowarD1's Avatar
HowarD1
HowarD1 is offline
You are not the first one with this issue. See the following video on you tube for how to......with a little humor.
6.0L power stroke egr repair - YouTube
This link should take you to 6.0L power stroke egr repair on you tube.
Old 11-13-2011, 08:45 AM
bismic's Avatar
bismic
One of the pics in the album should be the tool I used.
Old 11-13-2011, 09:41 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
After turning it a little, put your pry tool of choice under the tab. Don't try to pry it out all in one motion, put some pressure on it with the pry bar and rock it back and forth. There is very little play but it will move slightly each way and come up a tiny bit each rock. After just a few rocks it will suddenly pop loose. Should go back in with a firm push, no rocking or twisting.
Old 11-13-2011, 12:22 PM
bebeard's Avatar
bebeard
bebeard is offline
EGR Valve won't budge
thanks everyone .... I am going to work on this again this afternoon after all the suggestions.
Will post the results when I am done.
thanks...
Old 11-13-2011, 12:27 PM
droffan's Avatar
droffan
droffan is offline
thanks...
rotate the vavle to expose bolt holes. wrap wire (about 12 inches) through each hole. wrap ends on a large screwdriver and find a fulcrum point and lift...easy exit.
Old 11-13-2011, 12:34 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
same one I use to
actuly I used 2 of those little pry bars it helps to pry up with 2 bars so it comes out evenly
but 1 will work you just need to alternate side with the pry bar as it comes out or it will bind on itself
Old 11-13-2011, 03:41 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
I've done both ways.
Wire through holes, piece of rebar used alternator as leverage.
Pry bar.
Both worked.
Old 11-13-2011, 04:26 PM
bebeard's Avatar
bebeard
bebeard is offline
well, i have been working on it for abt two hrs still nothing. feels like there is a strong suction to it...
any other suggestions before i have to pay the man for his services?
thx
Old 11-13-2011, 04:35 PM
bismic's Avatar
bismic
Did you try the tool I suggested (available at all Home Depots)? You want something with a flat/beveled edge (as thin of an edge as possible) that can fit in the crevice but is wide enough to apply some force. A thin edge can catch the bottom flange of the EGR valve (between the bottom of the valve body and the intake flange). Don't even need to rotate the valve.
Old 11-13-2011, 04:38 PM
JonArmy's Avatar
JonArmy
JonArmy is offline
The first time I did mine it felt HARD and was tough to take out. I turned it so that the bolt holes were away from each other. I got a pry tool and carefully worked on each sides and finally wham it was out.
Old 11-13-2011, 04:44 PM
bebeard's Avatar
bebeard
bebeard is offline
thanks for the confidence booster ....
will try again tomorrow..
i can get it to turn and "wiggle' a little but that is it..
thanks again..
Brook
Old 11-13-2011, 04:57 PM
wulfman's Avatar
wulfman
wulfman is offline
Look bebeard try the wire trick and the little pry bar at same time its the way i do it , a large crow bar and lift on the wire against the alternater and pry with the little pry bar. The little pry bar can be bought at home depot.
Quick Reply: EGR Valve Won't Budge...
