Lowering fuel pressure when starting
Old Nov 20, 2011 | 03:45 PM
rla2005's Avatar
rla2005
Originally Posted by RIKIL
It is. I can tell you this because I just got the truck running. I ran it for about 5 min and realized that I needed more coolant so I got to go get some.
There was a good amount of smoke coming out of the exhaust. Not sure how long that should last for but everything seemed OK. The oil pressure was normal and it was idling fine at 2300 RPM. No strange bangs or noises. I am just not sure what to expect. It's my first motor I installed, let alone put together. I am surprised I got it to start.
It sounds to me like you are one tooth off when you stabbed the distributor. On a sequential fire fuel injected vehicle you need to make sure you have the #1 plug and the "signature" vane on the stator ( aka PIP) in proper alignment. The PCM needs to know where the crank/cam is in relation to energizing the proper fuel injector.
Joel5.0 has some great info in the first few posts of this thread he started: EFI DO's and DONT's (A Work in Progress)
That may not be the true source of your many issues you have with this build, but it will become an issue once you start to drive and tune that thing.
Old Nov 20, 2011 | 04:09 PM
RIKIL's Avatar
RIKIL
Well something went wrong and I am not yet sure what it is. After I got back from the store the smoke stopped (I think it was a bit of the moly lube burning off) and I added more coolant, I could tell when the thermostat opened and a few min after that a lot of coolant started leaking from the passenger side near the firewall. I wasn't able to tell where it was coming from and I was letting the motor cool when I noticed some coolant leaking from the seal on the timing cover where the crank goes in. So that can't be good.
I pulled the oil dipstick and it is a light brown and very thick.
Old Nov 20, 2011 | 04:40 PM
Slip ford man's Avatar
Slip ford man
Oh boy, best luck to you
Old Nov 20, 2011 | 04:47 PM
RIKIL's Avatar
RIKIL
Thanks a lot for everyone's help.
calebo10
Jun 8, 2023 07:20 AM
88/89bronco
1978 - 1996 Big Bronco
Jan 24, 2017 05:42 PM
T-ford
1983 - 2012 Ranger & B-Series
Aug 17, 2014 07:30 AM
sainty333
Jan 2, 2007 02:58 PM
jimshad
Dec 18, 2000 08:44 PM
