TIRED OF WARPED ROTORS AND looking for advice!! HEEEELLLLPPPPP!
My boat is about 11k on the trailer and has surge brakes on the trailer. The X has Napa Ultra Premium rotors and Hawk LTS pads and stops perfectly with no issues. This is with about 22k on the pads and rotors. Definitely check the brakes on the trailer and make sure they are doing their fair share. You can also upgrade the pads on the trailer to help as well. A good ceramic pad on the trailer can really make a difference over the organic pads most come with. The ceramic will keep the rust at bay and will last a little longer than the organic.
I had the exact same problem pulling my 28' Grady White which also tipps the scales around 12K loaded. The only thing that helped was running EBC premium rotors and Green Stuff pads. When I first put them on, they did the same as the others before and I called EBS and they told me to have them turned on the vehicle by someone who has a Pro Cut Lathe. I went to the local Firestone and they turned them. I had never heard of this before but 40K miles later and a full boat towing season later and not a problem.
BTW, my trailer has 3 axles and hydraulic disc brakes on each. That is a great boat you have, my dad has the exact same thing and we both tow them all over the east coast during the summers. Good times.
I'd also recommend replacing the calipers and flex hoses. I've seen sticky caliper pistons not retract and I also had a similar problem with an E350 where the liner of the flex hose had deteriorated and was blocking the backflow of brake fluid when releasing the brakes. It was holding the caliper out and overheating the brakes. New flex hoses fixed the problem.
We've owned our 2000 Excursion for 9 years, we bought it with 20,100 miles on it and I've replaced the rotors once and had them turned twice. In that nine year span it has always had a vibration in the front due to braking that seemed to be the worst around 40-45 mph. The vehicle was 100% stock including original shocks and leafsprings.
Last Monday (11/14/11) I installed a 6'' procomp lift and dual mx-6 shocks along with 37'' tires, the vibration from the braking is gone. Poor shocks and weak leafsprings will intensify this vibration... My point being a person shouldn't have thousands on a brake system which is adequate. Maybe weak suspension components are leading to premature brake failure, when you think of how heavy an excursion is with weak suspension all the load and weight is shifted to the frontend when you brake and puts extra strain the front pads and rotors... food for thought i guess
The trailer has surge brakes, its a boat trailer. I know the brakes work because I can feel em kick. The trailer has brakes, it was designed for the boat, but ya know I have never looked at the axles and looked to see if brakes are on one or more axles.
I think Im staying away from the drilled. LOL I read a huge post about the drilled rotors cracking, and I dont need that happening going down a mountain pass. LOL.
I just want the best rotor for my money, Not really caring what the cost is. The caliper pins are not frozen... have been before, thus replacement of all four calipers with life time warranty. Thats why when i do brakes, I just do all four.... I have a lift available and technicians that work for me. So what is the best rotor I can buy to avoid the hot spots and warping??
It sounds like you already need brakes on the Ex. I strongly suggest that you have someone go through the trailer brakes, too.
I had same problem.I tried performance rotors and hawk pads (they are great)
The problem was CALIPERS not releasing complete make pads rub against rotors
all the time cause heat warping rotors (a clue is after driving highways speeds
extended period steering wheel shacks a lot more) in town driving very little shake)
After market calipers are expensive (single or double piston) I checked with dealer
TSB bulletin for superceded calipers part nbrs.If money no issue go for performance aftermarket calipers and hawk pads Most are good BREMBO and WILDWOOD from JEGS
#29
It is a pump activated by your electric brake controller (Like a Prodigy Controller). It then uses a pump instead of the hitch-mounted master cylinder to send pressure to the brakes. They make a 1000 psi version for drum brakes, and a 1500 psi version for Disc brakes.
My "smallish" 23' aluminum boat doesn't have brakes at all on the E-Z Loader trailer. I intend on putting some disc brakes on it, but I have never liked the tongue/hitch mounted master cylinders. Once I saw the new Electric over Hydraulic set-up, I am trying to save money to get that set-up. Fortunately my boat hauling is comprised of a 5 mile jaunt to the gravel mountain pass, where I drop to 1st or second and then the engine hold me back for the 5 miles up and 5 miles down to the boat launch on the back-side of Kodiak Island. No traffic to worry about, so we go only as fast as necessary to get there and back safely.
Good Luck on both the trailer brakes and the Ex brakes. I am reading all this info, as I will be doing the brakes soon on my 00 EX and on my 02 F350, as they are pulsating, and the F350 has started to squeal a bit, which I think is my tell-tale "talking" to me that I need to change the brakes.
Garry in Kodiak, Alaska
#30
Here is a picture of the Electric-over-hydraulic brake unit.
GPL
10-23-2006 10:58 AM
