Help I'm stuck in 4wd
I am stuck in 4wd low. The lights do not come on on the dash. I am stuck out in the country with no money and really no easy help. Nearest mechanic I know is 50 miles away. It looks like the switch to engage the 4wd is electric and at the transfer case for the front gear box. Has an electric motor. Is there anyway to disengage this?
This is the second time today... Copy and paste...
First off, in order to go in and out of low range you have to have the transmission in neutral and your foot on the brake. I have found sometimes that a little bit of motion is also required, which is difficult because you have to get rolling, then put it in neutral, apply enough brake to activate the brake switch without stopping and then turn the 4WD **** out of low to 4 high.
If you're doing all of this and it still isn't working, you may have a bad relay. On the drivers side firewall under the hood are some relay boxes. One of the boxes will have two identical relays with nothing else. It is wrapped from the factory with black fabric electrical tape.
One of the relays is for moving the shift motor from 2WD to 4WD to 4Low. The other relay is for moving it from 4Low to 4WD to 2WD. Inspect the relays for corrosion, the switch their positions. If you can get out of 4WD now, then one of the relays is bad. You can get them from Ford for about $20 each. If this works I suggest replacing both of them.
P.S. In an absolute emergency, remove the shift motor from the transfer case and turn the shaft with a wrench. Just be careful not to bugger up the shaft.
1998 ford f250
Sounds like this might help.
Mine is a 1998 f250 and its stuck in four low. I'm sure I know how to put it in and out of four wheel drive so its some kind of mechanical malfunction.
There are two small connectors on the passenger side firewall that have vacume lines attatched. Two vacume lines are on each connector. Only 1 of the vacume lines on each connector have suction.
There is also an electric plug with two wires on each connector. The tops of the connectors have what feel like caps but they are not on tight. There is some play with them.
On the transfer case, there are also two vacume lines attached to a diaphram. The diaphram has an arm that is attatched to a lever. One of the vacume lines has suction, the other does not. When I disconnect the vacume line with suction, the lever moves but does not come out of four wheel drive. When I connect it to the other side, it stays in four low.
Thanks for the help
Thanks for the help
The following users liked this post:
still stuck
Well its been about a month since we worked on our truck but we're still stuck.
I would like to find a diagram of the vacuum lines, especially behind the dash.
Also, is there a way to test the relays? We didn't have any luck switching the lines.
When we are under the truck and remove the vacuum lines from the actuator on the transfer case, it moves a little but doesn't disengage.
Any help would be appreciated. We searched and found some info but still lost.
Skydivelout
05-12-2017 12:57 PM
hsauto
1997-2006 Expedition & Navigator
35
11-30-2016 03:43 PM
warren561
08-20-2015 05:07 PM
