1977 bronco 5.0 swap - Ford Truck Enthusiasts Forums
1966 - 1977 Early Broncos
Old 11-06-2011, 10:52 AM
coltharp22
coltharp22 is offline
coltharp22 is starting off with a positive reputation.
I HAVE INSTALLED A 5.0 ENGINE IN MY 1977 BRONCO AND HAVE HOOD CLEARANCE ISSUES. IS THERE A SET OF MOTOR MOUNTS AVAILABLE TO LOWER THE ENGINE? THROTTLE LINKAGE? ANY IDEAS? PLEASE HELP
Old 11-06-2011, 09:06 PM
MonsterTruck\m/
MonsterTruck\m/ is offline
MonsterTruck\m/ is starting off with a positive reputation.
what year motor? i swaped my I6 in my 68 bronco with a 77 302
Old 11-07-2011, 07:11 AM
chrlsful's Avatar
chrlsful
chrlsful is offline
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
That may B it. Thoes motors came in them all 11 yrs.
It should have mechanical linkage. There wuz a lill lever on the firewall...
Go to Bronco Driver mag or classis broncos dot comm. Plenty of DIY builds @ either.
Old 11-07-2011, 08:36 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
If it's a later model FI engine, there is a difference in the intake plenum height between car and truck engines. You may need to swap that out. No personal experience with it, but I do know of many that had to be changed.
Old 11-16-2011, 10:45 PM
scarey1
scarey1 is offline
scarey1 is gaining momentum as a positive member of FTE.
clearence
If you swapped in an EFI,you may want to try an intake from a 1991-1993 Cougar/Thunderbird 5.0 they are made to sit lower. We put in 1991 Tbird engine. it was missing the acc. and bought a mustang complete core for the parts. We used the mustang set up,but I noticed the tbird intake was a good 2 inches lower.(we have it if you may want it) hope this he;lps,scott
Old 11-20-2011, 08:43 AM
Boba Fett's Avatar
Boba Fett
Boba Fett is offline
Boba Fett is starting off with a positive reputation.
Like scarey1 says... you might need another intake.... these bronco hoods are tight... I found that out when I started swapping motors.... For instance... using a stock 302 block you can get a stock intake to fit with a 2bbl, or an edelbrock performer... the lowest model.... but if you have to step up to a performer RPM... hello hood scoop.... or you need a body lift to get the stock hood to close.... I would search craigslist of hit a u pull it yard and try to find another intake and see if the problem is fixed or do a 1" body lift, or a hood scoop or fiberglass hood....
Old 11-20-2011, 03:40 PM
chrlsful's Avatar
chrlsful
chrlsful is offline
My prob is I'd never get the windshield dropped if I did that (only the body lift will wrk - plus more tricks). 28 yrs ago B4 I got the bronk PO put a '68 car 170 in. IT hits the hood even with the "off set" air cleaner. I'd recommend them to any 1 who has any clearance probs - as a first attempt @ correction. It only adds 1/4 - 1/2 inch but 4 me the YF is still too high. Motor sits on the higher car towers & mounts.
I'll hafta slot another style towers to get the 250 in (add 2" to the 170's deck to get a 250). Others have convinced me to keep the mounts. Originally I wuz gunna 'hard mount' for space savings. That's why the 1st entry wuz "towers n mounts".
Old 01-30-2014, 10:31 PM
forsaith
forsaith is offline
forsaith is starting off with a positive reputation.
I know this thread is old, but I bought a '67 Bronco that a kid put in a 5.0 from an '87 Bronco. 1" body lift and still had hood clearance issues. I removed the intake manifold and plenum and put in both from an '87 Crown Vic., so far so good. Took care of the clearance, still working on vacuum and wiring.
Old 04-06-2014, 09:16 PM
Edones06's Avatar
Edones06
Edones06 is offline
Edones06 is starting off with a positive reputation.
I use a crown vic intake on my efi swap in my 72. I am running a 3 inch body lift and mine has room but it is close...
Old 04-10-2014, 11:11 AM
chrlsful's Avatar
chrlsful
chrlsful is offline
WoW, if that's a BL AND a Car motor/intake
I'm surprised, not what I heard over the yrs.
Wonder Y...
mounts? towers? humm...
hairba11
New Member Introductions
01-11-2017 09:05 AM
Tgure
Ford Truck Parts for Sale
02-26-2016 01:38 PM
RCAMN
01-19-2016 05:45 PM
dads1977
11-28-2015 09:04 AM
carsonduke
05-05-2011 07:19 PM
Quick Reply: 1977 bronco 5.0 swap
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
