Leaky Throttle body
Old Apr 11, 2003 | 05:05 PM
Scooter's95's Avatar
Scooter's95
Question Leaky Throttle body
Hi, I have a 95 f150 with a 302 and I think the throttle body has a slow fuel leak. It's oily on the bottom of it and spreads all the way to my air filter(K&N FIPK). do these trucks usually leak some fuel through there?
I also beat my brothers 93 chev 350 today
Old Apr 11, 2003 | 07:24 PM
MustangGT221's Avatar
MustangGT221
Leaky Throttle body
Welcome to FTE!
Put some of the liquid on your finger and smell it, smell like gas? You said "oily" so I'm not sure. Doesn't the throttle body only let air in? I believe the injectors take care of the fuel.
Old Apr 11, 2003 | 09:23 PM
mrwizard's Avatar
mrwizard
Leaky Throttle body
There shouldn't be any fuel there. The fuel doesn't get into the combustion sequence until the fuel injectors right in front of each cylinder.
Old Apr 11, 2003 | 09:40 PM
PigFarmer's Avatar
PigFarmer
Leaky Throttle body
The only fluid that is associated with the throttle body is coolant. Coolant is circulated thru the throttle body to eliminate frost up under certain weather conditions. Check those small rubber coolant lines for leakage. There are also a couple of small frost plugs on the throttle body that coolant could come seep out of too.
Randy
