How many quarts should my rear differential take?
I had been eye balling the drops of oil out of my rear diff and that is probably the next project.
My 1960 F100 rear diff. I am pretty sure it is a 9". How many quarts should it take? (seeing as I do not have a shop manual)
I got the bolt loose and dropped a quart in and I am astonished that it is still not full! (though I could be the first person to open it in 20 years)
I going to town to get more and maybe something to suck it all out for a complete change.
Anyone use that Lucas Oil Gear stuff?
Baumst, I never used the Lucas product.I'd be inclined to just stay with standard 80/90 wt gear oil,unless I was starting from scratch with a rebuild.At any rate,it won't heal any noises/problems.
Also,can't say how much the diff will take.I buy a gallon with a pump,and pump slowly till it comes out the fill plug,seal it back up and good to go.It's usually cheaper for a gallon,and I can also use it in the tranny.
Yeah... that's what I am thinking... pumping it in. The quart I put in was shocking. There is no issue, no noise... no anything. I am just thinking...."Drops on drive way, change gasket project. Better check oil level." Cool stuff...
Niners beat Giants this weekend... They are the real deal.
doublecanister
05-16-2012 12:13 PM
