F350 won't start
NICE, glad you found the problem. Things to think about.
14.13. Can a bad battery harm the charging system or starter?
A bad or weak starting battery causes additional stress on a charging system, starter motor or starter solenoid. It can cause premature failures due to compensating for the voltage or current. If you replace a battery, alternator, voltage regulator or starter, you should test the other components for damage and repair or replace them as required.
Wolfe Pestorius
11-29-2016 06:06 PM
