Tuning a holley 2300 for a 390
Yesterday I replaced my old motorcraft 2bbl with brand new Holley 2bbl! It's the 500cfm 2300 series carb, and it's done wonders for my engine! I don't get gas in the oil anymore, (the old motorcraft was constantly blowing power valves) and a myriad of vacuum leaks made it impossible to tune, and some other stuff, like sticky throttle plates.
I put the Holley on and bam! The truck runs smooth, idles as low as I care to set it, and the mixture screws actually adjust the mixture! In other words, it all works!
I have only one complaint about the Holley, I've lost some of my low end torque. I managed to get some of it back by playing with the timing, but any tips for tuning it to get my torque back? If not I'll just get used to it, this carb has made my old 390 run better than ever!
One more thing, should I lube the chokes linkages and the throttle shafts? Anything in particular I should use, or just some motor oil?
Sam
Sam
That makes sense, if I put my foot into it my torque comes back, but it takes a lot more throttle than I like to give it. So I just adjust it with the lock-nut on the linkage?
Sam
Sam
I spent some time today tuning that carb, as it turns out the accelerator pump was kicking in too early! I backed it off, and re-set the timing and the thing runs like a champ!
I just hope that blowback protection works the way it should, my old 390 has a burnt valve and it backfires every once in a while. I think that was one of the things killing the motorcraft.
Sam
Sam
Good to know, I've had it on the truck for the last few days and it made the old rig run great! That is, untill yesterday, when something finally let go inside the motor. I'm not sure what happened, but I've had an intermittent missfire for quite a while but it turned into a constant one yesterday... The truck smells like it's running raw gas out the tailpipe and it idles so sough it hardly runs...
Sam
Sam
You lost low end power because you went from a 350 CFM carb to a 500 CFM carb. A bigger carb with the same number of venturis will do that every time. You would have been better off going with a 600 CFM 4 barrel. Even better low end and better top end. A bigger carb always has consequences. Basic carberation info would have told you this.
The problem is not the CFM, it is not enough holes. A Holley tech once told me that "a lot of little holes will out perform a couple of big holes every time." It has to do with air velocity thru the venturi and 2 big holes suck at low speed for moving air.
Half a 750 4 bbl is not "two big holes" for a 390. Been there, tried it too many times. A 500 cfm 2 bbl works perfectly on a 390 (and a 400 too). A 600 4 bbl meantime has a tendency to want to open the secondaries too often, on a 390 due to the higher vacuum generated, unless you install the stiffest secondary spring.
Same principal as the the 4 valve heads. A pair of 1" intake valves will flow more air than a single 2", but they also have a higher velocity even at low RPM. Velocity makes a HUGE difference, in the grand scheme of things.
And this is why Ford dropped the FE big port heads and intakes in 1966 except on the truly Hi-Po engines and went to the small ports heads and intakes with street improved performance.
