Long cranking times
Long cranking times
Hey guys, having a strange prob with my '02 F3350 SRW. Took the truck for a new paint job(tuxedo black, '05 Harley Headlights, Grille and Chrome Bumper) Truck started and ran like a champ when I took it there. They had it for 32 days (!) I picked it up, an immediately noticed I had to crank it a lot longer than normal to start, a solid 10+ seconds at least. I thought maybe just cause it hadn't ran for more tham a min or two in the last month, just needed a good run. Wrong! Had the truck put for a 10 min rip (still not totally back together) Went to start it up 5 mins after shut down, same situation.
Had the engine out in August, did the oil pan, all glow plugs, upgraded to the Int. bellowed up pipes, installed a Dino Fuels CCK and changed a fuel line from the bowl to the pass. side head. Also had ex. manifolds planed and installed new studs.
Noticed a plug haning from the D/S innner fender upon return from body shop, but I'm not sure where it came from. Doesn't really look as though it was plugged in. I'm a bit discouraged, spent a lot of $$$ on the old girl, just hoping its not serious.
Also checked GPR with test light, seems to check out, though I didn't use DMM
Thanks
Thanks
Charged batteries when I got truck back to the shop. Engine whirls over real fast, changed starter about a year ago, two bolt style. I don't have any bad connections that I'm aware of, changed the cable to the starter when I changed the starter, to a 3 ought cable, all terminals are clean and tight at batteries.... Won't be able to get to it again till monday...
ghunt
22
12-27-2008 09:13 PM
