Bronco II Ford Bronco II
What if?????
Old Apr 10, 2003 | 07:28 PM
baddmove's Avatar
baddmove
What if?????
i just wanted to raise the hieght of the tires without putting a body lift kit on..hmmm?
Old Apr 11, 2003 | 05:47 AM
AbadDriver's Avatar
AbadDriver
What if?????
you can get away wtih 30's with minimal rubbing(when susp. compresses)
Old Apr 11, 2003 | 07:10 PM
Oceanwave's Avatar
Oceanwave
What if?????
15 x 235\75 is the largest I could fit before lifting and they rubbed on tight left.
Old Apr 11, 2003 | 08:53 PM
baddmove's Avatar
baddmove
What if?????
o.k...thanx all..was just wondering
Old Apr 12, 2003 | 03:45 PM
Metalstorm's Avatar
Metalstorm
What if?????
I discovered from these boards that not all BIIs are exactly the same and it's not dependant on the year. Most take a 235/75 as the biggest but a few like mine will take a 30x9.50 and have minimal rubbing on full flex. On the street they work just fine with no rubbing at all. I plan on doing a little front fender trimming so I can run 31's on my stock BII (don't ever want body lift and suspension lift is too expensive right now) but if I wasn't, I'd probably drop down to the 235s. I think they're better for the rougher terrain than the 30"s and the size difference is really miniscule.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
