thermostat
well think of it this way. The thermostat holds coolant back until it reaches a certain temperature i.e. 185f. when that's hit then it allows coolant to flow to the radiator. the largest reason why many oem applications call for the 185 degree thermostat is one, engine performance as said above. second, so that there is a good transfer of heat through the block and in the winter the heater core. What exactly made you wanna run with a lower thermostat?
When i first got my truck it had a 165 in it... not really sure why. The cooler thermostat helps performance a little, but really increases wear on the internals, increases emissions and virtually kills the heater. 180 or 195 would be the way to go. Some engines you can get a 210.
The only good thing about a 165 thermostat is that is the temp that makes an automatic the happiest.
HOTRODSRJ’s COOLING TIPS Operating temperature vs power and longevity!
JGreen236
04-14-2020 07:52 AM
Sbroom
06-03-2013 08:49 PM
wyotommy
15
03-03-2004 09:40 PM
'95 Splash 4.0V6
01-03-2004 03:19 AM
