Changing axle U joints on a 2006 f350
Can't help you on the ujoints, but on the hubs, you'll need to get a service kit from Ford that has new o-rings and bolts, they're pretty explicit on not reusing the o-rings. They even give you 2 in the kit, one to test fit and one to actually use.
Would be a good time to clean them up and relube them anyway...here's a link to doing that.
https://www.ford-trucks.com/forums/9...with-pics.html
Wow, pretty sure they're supposed to come out in a unit, like the pics in that link I posted. If you're lucky you might be able to get them back together and pull the whole thing out...if not I think you're looking at a new hub. And no one makes a replacement for the 2005 and up hubs, so you're stuck w/ Ford. It all just slides out though, there's no rings or clips holding the locking hub itself in.
Well, I know my 4X4 still works, So I don't think my hubs are bad...atleast I hope not.
I took off my pass side to lube it up since it was hard to turn, I didn't take off my driverside, thats the side I am doing since its bad.
Im going to do this tonight. So hopefully it all goes smoothly. Who knows
