Headlights.....PIAA Xtreme White PLUS or Philips X-treme Power?
Looking for better illumination for the upcoming winter night driving. Hi-beams aren't to bad but the lows are marginal at best. I know HID is an option but don't even know if there are any "legal" ones available. And if there are I know I dont want to shell out the coin for them. SO I am basically looking at a bulb change. I wish HIR bulbs were available in H13/9008 but no luck there.
Anyway, I put Silverstar Ultras on another vehicle and was less than impressed. What do you guys think of the PIAA Xtreme White PLUS?? What does the PLUS signify?
PIAA
How about the Philips X-treme Power?
X-treme Power
PIAA
X-treme Power
PIAA
X-treme Power
PIAA
X-treme Power
ken
FYI just tried to replace 9145 driving lights with 9006 55w PIAA extremes, they don't fit, i tried everything darn it. Any help appreciated I just dropped big coin so if there is a way to make them work I am all ears. The H13s are doing fine for 1 year. This is in my 2005 so any tips appreciated.
I put 55w HIDs on (for under $100) and it made a huge improvements. I haven't been pulled over or even flashed but I did adjust the beam down.
Take you stock 9145s and put them side by side with the 9006, match up the bases and trim the taps on the 9006s. It will fit, I have 9005s in mine.
The problem was the base of the bulb would not fit into the cylinder and twist lock in place. About two mm to big around. Tabs are different too, they are at slightly different angle and thicker. I have put them in my wife's Rav4. I am going to try and buy 9005s and see if they will fit into the cylinder base. If they don't the Rav4 will get high beam upgrade too. I was hoping the 55w version would fit. Now the 9005 are high beam at 65 watt so it may be I can only run on the open road.
So I ask the question, how does one change a light bulb, headlight, side light, or turn signals on the new 2011? Mostly just curiousity but it might be important someday on the road and no internet to ask the question. I would hate to have to go to any dealer to change a light bulb. Anyone???
HID Kits, BMW Aftermarket Bumpers & Lighting, DEPO - DDM Tuning
Search and there are several threads including an install.
Here is how I would do it. More work, but easier in the end.
Three bolts on top of the center chrome grill, take them out, pull up and out and the big chrome grill comes off.
Then, there are two or three bolts holding the headlight assembly on, take them out and the whole headlight will come off and you can put it on your workbench.
They are all metric bolts.
OK,
I went back to Pep Boys today and they still had the Silverstar Ultra's on sale, so I bought them.
The Install:
it is easier to take out the center grill - there are 4 screws up on top, then about 5 push connectors on the bottom to get the grill out. You can push down on them with a screwdriver and then pull the grill out. There is also a little tab on the left side that holds a rubber insulator that needs to be removed. All the bolts are 10MM.
Each headlight is held in by 4 screws - one on top, two on the side, and one underneith.
once you have them out, its twist and replace the lights.
now the Silverstars -
I changed them out at night so I could judge them, changing one out and comparing it to the stock. It's obviously brighter, but not worlds difference - and now where close to HID's.
however, for 35 bucks, its a worthwild investment to help get some more light out.
Next to to figure out how to keep the driving lights on when the high beams are on.
I know someone posted about a controller that does it - guess I need to research it.
The Install:
