Some upgrades to the Ranger and a few questions
Hey guys/gals i am slowly putting together my 1999 Ford ranger which my younger brother will be getting when i get my lightning here in a few months and figured i would post some pictures of the upgrades and also a had a few questions. Heres some pictures of the upgrades and will be adding a few over the next few days.
Pictures of the new tint, 35 percent of the front windows including visor stripe and i believe its 15 on the back windows.
The new system, 2 brand new Rockford Fosgate P2's in a Super bass ported box which is line-xed, powered by a Kenwood Excelon amp getting 254 watts rms to each sub at 2 ohms. New interstate battery providing the juice with i believe just over 800 cranking amps and Rockford Fosgate amp kit. The head unit is a Kenwood Excelon model # KDC-X395 which has ipod hookup and everything else you can think of and provides about 50 watts rms to each speaker. The speakers are still factory for now. I was told it hits about 136 db's thanks to the small cab space I am in the process of routing the ipod connector and aux wire to inside the center console.
I am in the process of blacking everything out, I will be painting the rims, and rear bumper next. Then will be applying VHT spray tint on the tail lights and turn signals with a light coat. I thought using a foam brush and painting it on would be fine but didnt turn out as good as i thought but will probably sand it down and spray it down the road.
I also removed the mud flaps and put in a drop in bed liner which i will take pictures of tommorow. I will be doing the exhaust hopefully this week like the lightning trucks. I already have the 3.5" slash cut tips painted gloss black and the piping i just have to get it welded on the muffler is already off. I may also start painting a few engine bay parts and clean up the wiring. I may paint a few interior parts to match the outside i have not yet decided. The future plans will be a 3/4 JDM drop kit, 18" rims, and may do a 5.0 swap depending on the budget. Ill try and get a video of the system and exhaust when it gets done this week if i can. Be free to let me know if you guys can think of anything else that may look good i am always up for ideas
My questions pertain to some maintenance. I was told there is some certain hoses that get clogged if the truck sits for awhile, which hoses are they? Its the 3.0 flex fuel and it sat for about 2 years before i bought it. I also plan on cleaning the MAF and throttle body is there anything else i should clean? The reason i am doing this is the truck will ping sometimes really bad on acceleration it has a mind of its own. The plugs and wires were replaced 30k miles ago from what i have been told. I also ran seafoam through the vacuum line which seems to helped alot but it still pings bad every now and then. I appreciate any input
What brand of plugs and wires were installed? Rangers seem partial to Motorcraft plugs and wires. Double platinum plugs would be a good choice.
Also, I would suggest cleaning the idle air control (IAC) valve.
When was the fuel filter last changed. If you don't know, it is something to consider changing.
What brand of plugs and wires were installed? Rangers seem partial to Motorcract plugs and wires. Double platinum plugs would be a good choice.
highoctane74
85
02-26-2017 06:29 AM
1998F150XLT
Vehicles for Sale
04-17-2015 08:13 AM
david.brady
29
07-18-2013 11:16 AM
DasCheckers
04-03-2009 12:55 PM
