4x4 shifter
Old Oct 25, 2011 | 09:20 PM
collinft's Avatar
collinft
4x4 shifter
what is it supposed to feel like when you shift the transfer case??when i shift it feels smooth all the way through.is it supposed to click in each position or is this how they are?the t case is a np205 and np435 tranny.the truck is a 78 f 150.
Old Oct 25, 2011 | 09:41 PM
kingford72's Avatar
kingford72
you should feel it go into each gear. Mines never been apart in its life and you got to pull or push like crazy to get in gear. The np 205 has ball bearings and detents in the shift rods to index them with each gear, I have to check on this to be sure. Did you check to see if you linkage is still hooked up or maybe you lost a set screw that holds a ball and spring in.
Old Oct 25, 2011 | 09:56 PM
kingford72's Avatar
kingford72
how convenient, the site that used to have info on modifying shift rails for dual sticking the 205 doesn't have the info up any more, probably because they are now selling the modified shift rails them selves.
Old Oct 25, 2011 | 10:52 PM
collinft's Avatar
collinft
i think its all hooked up cause i can shift in and out of 4x4 but cant feel it shift.i just find neutral and go from there.
GeorgePBurdell
1983 - 2012 Ranger & B-Series
Aug 13, 2015 08:07 AM
Prandyseth
Bronco II
Feb 24, 2012 05:57 PM
kevin510
2004 - 2008 F150
Nov 8, 2005 09:12 AM
joshsombo
Jun 28, 2005 01:17 PM
usherac21
Dec 5, 2004 11:22 PM
