Installing Power Steering in 1991 Ranger (4cyl)
I did this on a 1994 of mine it had dealer added air so it already had the bracket I bought a reman pump, a pulley and a salvage yard steering box. The biggest thing is you will need the slip bracket between the steering shaft and the steering gear and it is pretty year specfic. The steering gear is the same for years. I had to recenter the steering when I got it all together but that wasn't to bad. If you don't want to try that then an alignment shop can set it for you. I did mine for less then $100
Alcaeus
27
10-14-2009 12:56 AM
medicpg
1983 - 2012 Ranger & B-Series
04-02-2008 05:42 PM
