1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
61 Signal cam issues
Old 11-19-2011, 01:30 PM
64blue's Avatar
64blue
64blue is offline
I have a 61 unibody and I am using the original three on the tree column. I am having real issues finding all of the "guts". For the signal and horn assembly located under the steering wheel. Does anyone have a diagram? Will the parts from a Falcon work?
Old 11-21-2011, 05:35 PM
garbz2's Avatar
garbz2
garbz2 is offline
The plate assembly is metal. Only the switch needs to be replaced if bad. Dennis Carpenter lists the switch for $40.00 PN C0DZ-13341-A I know of no one who carries the complete unit.
If you need the entire unit you will have to scrounge one out of a F100 F250 61 or 62
Garbz
Old 11-25-2011, 03:34 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 64blue
I have a 61 unibody and I am using the original three on the tree column. I am having real issues finding all of the "guts."
For the signal and horn assembly located under the steering wheel. Will the parts from a Falcon work?
Same-o same-o: 1961/62 F100/250 2WD & 1960/62 Falcon/Comet
CODF-13304-A .. T/S Switch Mounting Plate / Obsolete
WESLEY OBSOLETE PARTS in Liberty KY has 4 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 8 = 800-543-4959.
CODZ-13341-A .. T/S Switch-less mounting plate / Obsolete
WESLEY OBSOLETE PARTS has 10.
GREEN SALES CO. has 11.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 116 = 800-476-9653.
What horn parts are you asking for? Does your truck have a horn ring ot horn button?
sonny1965
06-24-2014 04:42 PM
P38fighter
05-24-2014 07:28 AM
unibody madness
03-14-2013 10:12 AM
65F100390
04-17-2012 08:14 PM
White97
11-06-2009 05:05 PM
Quick Reply: 61 Signal cam issues
