Surging, especially when in Drive or Reverse?
Old Oct 19, 2011 | 12:29 PM
edzeb's Avatar
edzeb
Within the last two weeks my E350 has started to surge every once in while, most noticebly when stopped, in Drive or Reverse with the brakes on. Then it will stop duing it? It does it when cold or warm, but I have noticed it more when it is warm. The van is stock, except for a Banks Sindwinder Turbo kit.
Anyone have any ideas? Help!
It makes backing up with a trailer or being at a stoplight rather tuff!
Old Oct 19, 2011 | 12:35 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
Not sure but if it's doing like mine did it was the lift pump.... I hooked me electric pump up and it went away
Old Oct 19, 2011 | 01:12 PM
edzeb's Avatar
edzeb
It will 'stumble' a little when idling too. When I rev it up in park, or press on the pedal it revs fine. It only seems to surge when in gear and stopped with the brakes on, or stumbling some at idle in park.
Old Oct 19, 2011 | 02:03 PM
86f250XLT-4x4
Sounds like what mine was doing I prefer my electric fuel pump
Old Oct 19, 2011 | 06:48 PM
IDIDieselJohn's Avatar
IDIDieselJohn
My 7.3 was also doing that untill the mechanical fuel pump completely died in the middle of winter. Died at home at least.
But what's the mileage on the van? Has it ever had a tune up? Sure won't hurt it if the injectors and IP are original and have over 150k on them.
Get ready to write a book of curse words doing a tune up on a van.
Old Oct 20, 2011 | 08:22 AM
edzeb's Avatar
edzeb
It has 181K, but has had a pump and injector rebuild @ about 150k-ish. Thanks for the input, I will change the pump (their cheap) and see what we get! Any reason that some guys go to electric pumps?
Old Oct 20, 2011 | 10:26 AM
eatont9999's Avatar
eatont9999
My truck was doing the exact same thing a week or two ago. I have a brand new lift pump, IP and injectors. My best guess is air intrusion somewhere in the fuel system. If you are experiencing this issue on 1/4 tank or less, your fuel pickup could have rotted off and you are sucking air as if the tank were getting empty.
Old Oct 20, 2011 | 10:50 AM
86f250XLT-4x4
And If what eatont9999 said isn't the case or ididieseljohn said.... I prefer the electric fuel pump because it is a more constant fuel pressure you can actually have a small power increase due to better and more constant pressure... Just for the heck of it I bypassed my electric fuel pump and within 2 hours I was hooking it back up
GabezF250
50
May 2, 2025 02:33 PM
95_F2504x4_5.8
Feb 18, 2016 08:27 PM
Kody Nelson
May 4, 2015 12:47 PM
towandcamp
Nov 3, 2006 08:52 PM
