Possible major transmission problem - HELP
Old Oct 18, 2011 | 11:49 AM
maldbwmjr's Avatar
maldbwmjr
Last night, as I drove my 98 Expy out of the driveway and gave it gas, it started shaking - very roughly. I put it in reverse and drove it back (didn't shake) into the driveway so that I could try it again in the morning. Took it out today and the same thing happened. Jacked it up, disconnected the rear axle, put it in Drive, and the problem still occurred when I gave it gas - idle was OK. Could it be the transfer case? Reason I ask is that this is a rebuilt transmission that I purchased from a Ford dealer and installed several years ago. Has it died or is there another reason why this is happening? Thanks in advance for your help.
Old Oct 18, 2011 | 12:34 PM
chunger's Avatar
chunger
How's the fluid level? Sounds like it could be low. Does it look red and smell ok? Or burnt?
Old Oct 18, 2011 | 01:24 PM
maldbwmjr's Avatar
maldbwmjr
Fluid level and quality is fine - I make sure that it's OK as that's what killed my original tranny - I forgot to check the level and burnt out the original tranny.
Old Oct 18, 2011 | 01:27 PM
alloro's Avatar
alloro
It could just be a misfire in the engine. But if you're positive it's not the engine, then assuming no bolts are loose, it's probably a bad torque converter.
Old Oct 18, 2011 | 02:30 PM
maldbwmjr's Avatar
maldbwmjr
Thanks for the tip. I'm not getting any codes, so I don't think it's the engine. Can the torque converter be changed? If so, how hard is it to change?
Old Oct 18, 2011 | 03:03 PM
TerryB99's Avatar
TerryB99
Pull out the tranny, the torque converter will be looking at you,
Seriously, if you can pull out the tranny, you wont have any problems.
Old Oct 18, 2011 | 03:06 PM
maldbwmjr's Avatar
maldbwmjr
Yikes! I changed the tranny by myself 3 years ago - not a pleasant experience. And yes, I remember what the TC looks like: a doughnut. Bummer that I have to go through all of that again.
Thanks for your help!
Old Oct 18, 2011 | 03:50 PM
Moto Mel's Avatar
Moto Mel
Put the truck in gear and give it a little gas with the brakes applied firmly, if the shaking starts it is possibly a problem that is engine related. Vacuum, electrical or fuel most likely. Did you get a new or reman T/C with the transmission?
Old Oct 18, 2011 | 08:04 PM
maldbwmjr's Avatar
maldbwmjr
I put the driveshaft back on and tried what you said - no rumble. I'll take out the transfer case next (oh joy) and see how that goes. As for the torque converter, I don't remember if I received one with the rebuilt tranny or if I wound up using the original. I'll dig up the tranny's papers and see if I can find anything about the TC.
Thanks for your help everyone! Much appreciated.
Old Oct 18, 2011 | 10:15 PM
TerryB99's Avatar
TerryB99
You would remember if you changed the torque convertor. It is bolted to the flywheel, Did you turn it a bit, take out a bolt, turn some more, take out another, etc?
ShrikeDM
23
Jun 17, 2014 04:46 PM
BillyBob69
62
Dec 12, 2010 08:42 PM
preppypyro
15
Jul 13, 2009 07:39 PM
truestory
Feb 22, 2005 09:38 PM
1977 F100 custom 302
Jan 14, 2004 05:56 AM
