1st start, trans.wont shift until warmed up
just put a new hpop,and new engine harness ,now when i start truck up in the morning if i do not let it warm up for awhile the trans does not shift out of first ,if i do no problems shifts smooth, i did not have this problem before work was done any ideas?
found the problem,altenator only putting out 9.8 volts and one bad battery,replaced both batteries and alt. guess sitting and warming up it had built enough juice to operate. i dont like bad mouthing mechs. but.... when i pulled battery covers off i found one of my matched set of batteries was replaced with a diffrent one wrong brand and wrong cranking amps after testing both wa la , guess which one was bad ,this was done while having hpop replaced ,no more work for him and a lesson learned,DO IT YOURSELF and you know what you get,thanks for replying everyone
XNAK
12-05-2012 10:46 AM
1967fordranger
01-24-2002 10:43 PM
