Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- How to Replace Rear Shocks
Step by step instructions for do-it-yourself repairs
Bilstein 5100 Shock install with VIDEO!!!
#31
#32
#33
Superduty Brothers and Sisters..Here is my first video for the FTE forum. I installed Bilstein 5100 shocks and video tapped it. The front shock part number is 24-186018 and rear shock part number is 24-186025. These shocks fit a 2011 F350 Superduty (Stock, No lift or leveling)
Please don’t ask me why I said “Good to go” several times in the video! I have no idea why! Enjoy
Bilstein Shock Install_Big_Sarge.wmv - YouTube
The reason you get very slow rebound on the stock shocks is because they are not high pressure nitrogen shocks like the bilstines and some of the other shocks. For that fact they are very low pressure if they have any at all. i had rancho 9000's on my 08 SD when i had it and they had faster rebound thenthe stock shocks and they are not a high pressure nitrogen shock but have more then stock. The stock shocks are relying on the spring to do the work, the high pressure nitrogen shocks have added spring rate because pressure in them. Regardless any of bilstine of the rancho's will ride better then the stock shocks as they are a better quilaty shock,
#34
#36
#37
Great video, haven't even got my VIN yet and I'm considering the mod. I've run 5100's on my 70 Bronco for a while and they have been great. One thought: You could use the allen wrench to hold the piston during torquing if you had a crows foot (right, we all have metric crows feet) for the torque wrench.
#39
Im going to get a impact wrench tonight, this way i wont have to leave ine middle of the install.
#40
Absolutely, I don't know how much room you would have for clearance though. If it's a tight fit you may want to have a buddy hold the Allen wrench from above or the inside, that way you can have a good hold on the torque and crow foot.
To be honest you really don't even need to bother with the torque wrench if you are used to turning wrenches. You should be able to get it within 3 lbs +/- 1 lb without worry.
#41
#42
#44
#45
