Im trying to fix the window motor on my 86 f150 i got the motor removed and hooked up the one i just got from the junk yard and it will only let the window up when i press down it does nothing i also checked the motor that came with the truck and the same thing happened so i assume there is a problem in the wire harness. any advice on this issue would be greatly appreciated
