02 7.3 no gp
P1211{2}
ICP Pressure Is Above/Below Desired, Faulty IPR Valve
P1211{1}{3}
ICP Pressure Uncontrollable, Pressure Above/Below Desired
P1670 is a IDM code.
Is the WTS (wait to start) light going on/off like normal? How long is it on for?
To test the ICP, unplug it checking the plug and wires for oil. Start the truck, if it runs better or there's oil it needs to be replaced.
It also could be the UVCH, but definitely check the ICP first. What did you use to pull codes?
P1211{1}{3}
Does the WTS light come on/off like normal? Get any smoke when trying to start?
Checked all your fuses?
I got truck running I think it was a combination of a few things Clean my. Plugins connections filled
HPOP And make sure that the batteries were up it started rtght up.the idale is real low and it is running rough just like before but after a wh.ile it will smooth out and run fine. yes I did put a new fuel pump on
edo488
15
08-21-2017 10:57 PM
tidexp
23
09-09-2012 08:37 PM
forhammer33
19
04-30-2012 11:05 PM
