Help!!, got muddy water in my intake, what did I possibly tear up
Well I pulled a bone head move, and decided to try to pass through a mud hole, and it had more water on top than I had thought. I got stuck, then she wouldnt rev past idle. I got pulled out and found my air filter was soaked and I had moisture in my intake tube. She never threw a ses light, and after I pulled the filter and used a rag to clean my intake, she cranked up just fine and drove home ok. What have I probably hurt, and is there anything I can do to repair it.
If we don't know what is damaged we can't tell you how to repair it.
This is for driving into the mud hole .
Next time use your mud hole dipstick.
FYI : Water and meth is injected post-turbo.
Edges could certainly be rough from neglecting the air filtering system. Is this an E99 turbo? If so you can always put in the rebuilt E99 turbo. If the turbo on the truck is not an E99 then putting the smaller E99 turbo on may be at the cost of a very small decrease in performance. May not even notice it in the SOTP. If the truck runs just as well post mud hole I would not even think about swapping the turbos unless I was really, really bored.
Thanks a ton, I wish the mobile site would let me rep you. The truck is a L99, so ill just leave everything alone, for now. This ole truck was well abused before I rescued her. I am gonna modify ky intake to keep this from happening again.
P.S. What is the sensor in the bottom of the filter box.
ford311
08-25-2002 09:01 AM
