Couple questions
Old Oct 13, 2011 | 08:30 PM
Captainsa's Avatar
Captainsa
Couple questions
Starting on a new project. 79' shortbed regular 2wd. Has 300-6 in it now have a 347 to put in. 1st question what do I need to change to put in347 motor mount wise. Number 2 I'm wanting some 1 3/4" headers, what headers are available. Will fox body shorties work. Or does someone make a big tube full length. I've looked but haven't found much.
Old Oct 13, 2011 | 09:14 PM
mblayton's Avatar
mblayton
Mount perches will be different, be carefull with full length headers as the frame cross member below the oil pan will more thn likely be different. I found this out doing a engine swap but I went from big block to small block and found that cross member would not allow for long tube headers so I ended up with shorties.
Old Oct 13, 2011 | 09:35 PM
Captainsa's Avatar
Captainsa
I figured perches would be different, I think it would be easier to put a bbf in it and have more performance parts to choose from. But I already have the 347 and everything to go with it. So it's going in.
Old Oct 17, 2011 | 03:43 PM
Captainsa's Avatar
Captainsa
Will a transmission that's behind a 300-6 fit a 302 is the bellhousing the same.
Old Oct 17, 2011 | 08:54 PM
4x4 Bart's Avatar
4x4 Bart
300 and 302 bell housing is the same
Old Oct 17, 2011 | 09:03 PM
Captainsa's Avatar
Captainsa
Cool, pretty sure the truck has a c6 in it. Now just gotta figure out the headers for it
Jrcrispy2
Dec 20, 2017 12:48 PM
Old_Crow
Aug 23, 2014 06:37 AM
1955effie
Jan 15, 2006 12:23 PM
Edberg
Nov 26, 2005 12:05 AM
