Missed Shift / Jerky going into 5th gear!!??
Old 10-19-2011, 07:31 PM
MNDiesel2's Avatar
MNDiesel2
MNDiesel2 is offline
So today I experienced something very odd. While in "D", my truck totally missed 5th gear, and reved to about 2500 rpms, before I took the foot out of the throttle, it then shifted in, and was normal. Tranny fluid temp was 133 degrees at the time. I wondered if I could reproduce it, but could not, but I did reproduce a couple of slow shift, and one hard shift, while accelerating the same way. Basically I accelerated medium/hard to half way through 3rd gear, and then backed off the throttle. The truck tried to shift directly to 5th all three instances.
I had been experiencing some rough shifts into 2nd, but only when cold, and fairly tolerable...and now this. I'll be making an appoitment tommorow and I suppose they'll want to reflash it....
Anyone else with shifting issues into 5th....guess I should search the forum first..
Thanks.
Chris
Old 10-19-2011, 08:03 PM
kper05's Avatar
kper05
kper05 is offline
Yep, give the forum a search.
My issue exist between 2nd and 3rd but I've read about owners with issues in 5th.
It's difficult to reproduce at will.
It happens after the second start of the day after a 3-5 hour soak.
My truck is a May 2010 build also.
Old 10-19-2011, 09:46 PM
MNDiesel2's Avatar
MNDiesel2
Hmmm....mine was on the second start of the day, but I had just run into Walmart to grab some batteres. It's within a mile of the dealership, so I'm gonna try and do the exact same timing when I bring it in, and test drive it with them. Hoping the outside temp is the same, so things can be replicated at least.....
Old 10-19-2011, 11:03 PM
kper05's Avatar
kper05
kper05 is offline
Hopefully it will mess up for you with a tech or service manager in the passenger seat.
(I understand the tech's are busy and they're not making money sitting in your truck.)
Most SM's are salary if they'll agree to ride with you.
I found shifting into 3rd gear manually ahead of time didn't seem to prevent the issue in [D] so it gives you more chances to replicate.
It's as if the computer has to fail in order to correct itself for a few days then must fail again (2nd start and only once) and repeat the learning process in a never ending loop.
Old 10-20-2011, 09:18 AM
harris25's Avatar
harris25
harris25 is offline
Has been happening on mine since day 1 as well as irregular shifts, slamming knocking real hard into gear. Have had the valve body, solinoids replaced, torque convertor filter, and transmission pump replaced all to no fix. Ford has no idea how to fix it.
F TOO FITTY
2017+ Super Duty
27
09-11-2018 08:32 AM
mpd579
6.7L Power Stroke Diesel
17
11-12-2011 11:05 PM
Danny Stroup
15
12-14-2010 01:07 PM
joshsombo
02-14-2006 12:32 AM
brackin
2004 - 2008 F150
10-31-2004 05:32 AM
Quick Reply: Missed Shift / Jerky going into 5th gear!!??
