My slick '65
My slick '65
Thought I would post up a few pics of my 1965 short bed. I bought this truck about 6 months ago. The previous owner had swapped in a 302 and C6. I drove it like that for a month or so before I decided to put an AOD in it. Made a HUGE difference driving it to work and back. Also bought the wheels and tires that are on it in these pics. I have wanted a set of Americans forever so I figured it was time to pony up and buy them. I recently bought a 76 longbed for parts. The 302 out of it will get freshened up and swapped into my 65 along with the disc brakes, power steering, and a set of drop beams. Should have enough done in a few months to start a build thread. Still needs alot of work but I am having a blast driving it while I work on it! Here are a couple of pics.
You'll be even happier with the Torque Thrusts (I bought some too) when you hear that your new disc brakes will fit inside them without the rotors fouling on the rim. If you have a spare wheel/tire you should make sure it comes off of a disc brake truck. Stock '66 wheels were for drum brakes and the rotors will hit - at least mine did.
Nice!..I've been thinking of a set of those wheels for mine but didn't kmow what it would
look like? now I do and it's SWEET!. ps, you can put a washer on each side of the hood
hinges on the front bolts, between the hood and hinge to draw your hood down in the back so it lines up a little better!..Trick I learned on this Site!..it works Great!
Thanks for all the comments guys! I appreciate it. The wheels definently made a HUGE difference in the look of this truck. It had some nasty wagon spoke wheels that were spray painted red on it when I bought it, so the change was pretty dramatic.
Thanks man. I am kinda old school, so I was going for an early 70's look with this truck. Well, immediate plans are to get the other 302 swapped in, get the power steering hooked up, and get the drop beams and discs installed. When it comes to long term plans, I would like to do a complete frame off. New front clip, axle flip in the rear, body/paint and interior. The works.
I am not sure if the washer trick will work on this hood. The hinges seem to be the problem. I can put some pressure on the hood and it will shut down tighter to close that gap. As I drive and hit bumps in the road it opens back up. I think I just need new hinges.
Gas4blood,
I thought the same thing about my hinges, it seems most of these old trucks have the
same problem if you look at a lot of pic's you'll see the hood popped up in the back.
The hinges are the culprit but I've heard some real ''horror'' stories of peeps replacing
the hinges and have the ''welded nut'' break off behind the cowl'' and no way to get to it...I could also push down on the back of my hood and would close the gap, it's up to you, but the washer thing really does work!!
Cool truck! They have that rear bumper right there in OKC at Classic Auto Parts on the south side of town for $210. Obsolete & Classic Auto Parts Online Catalog
Sometimes you can find them a little cheaper but you'll probably have to pay shipping so it may be a wash. You'll need the brackets & tag lights for it, too.
All the best.
Randy
Gas4blood,
Hey Gas,
All the best.
Randy
All the best.
Randy
