stupid rotted brake lines
  #31
Old 06-22-2015, 10:08 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
Originally Posted by 1 Excursion camper View Post
For the life of me I don`t know why all manuf. don`t put stainless lines in all their cars. It would be safer, and in the end the cost would only be maybe $5 more per vehicle. well worth it to have a safer vehicle on the road.
I have been asking that for years. With all the recalls and lawsuits because of safety you would think something so prone in the brake system would be mandatory stainless.
  #32
Old 06-22-2015, 10:15 PM
Tedster9's Avatar
Tedster9
Tedster9 is offline
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Isn't "stainless" more brittle? As an alloy that term covers a lot of territory. All this stuff is probably made overseas now anyway so it's anybodies guess what's in it from week to week. Sleep well, America.
  #33
Old 06-22-2015, 10:20 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
wpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputationwpnaes has a superb reputation
When I lived in the rust belt, I changed all steel brake lines every 10 yrs. Routine maintenance and not a big deal. Heck, I bet a lot of driver/users don't even change/flush brake fluid until a caliper goes south.
  #34
Old 06-25-2015, 05:39 PM
sddesigns's Avatar
sddesigns
sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Originally Posted by superdave02f552 View Post
the 8' near the filter you speak of where is that? there is not any 3/16 for the rear run until it hits the tee on the axle
You are correct, the 1/4 was from the rear tee forward, the 3/16 was from the tee to the rear calipers.
  #35
Old 06-25-2015, 05:41 PM
sddesigns's Avatar
sddesigns
The nickel copper alloy is standard on many European models, and is very easy to bend and flare.
  #36
Old 06-25-2015, 05:44 PM
sddesigns's Avatar
sddesigns
The fuel lines are stainless, at least on mine anyway!
I know my fuel filler neck and lines needed to be replaced, they were rotted through near the neck and would leak when filling.
  #37
Old 06-25-2015, 09:38 PM
BassFantasizer's Avatar
BassFantasizer
BassFantasizer is offline
BassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputation
Put me on that list. I've driven for almost 50 years, mostly in Florida, and have never flushed the brake fluid on a vehicle. Almost 500,000 mile on the 3 Fords that I have now and pads, shoes, and rotors is all I've done to the brakes. Same for all my previous Fords.
  #38
Old 06-26-2015, 08:09 AM
Snowseeker's Avatar
Snowseeker
I wish we could get 10 years out of a brake line!
If I were to do replacement of steel brakes lines as a preventive maintenance dead here I would have to do it every single year! I have new steel brake lines rot out within 2 years!
I have installing nicopp line in all our trucks now when first putting them on the road. Haven't had to replace a line yet on any of these!
  #39
Old 04-08-2016, 11:51 AM
Corndwg01
Corndwg01 is offline
Corndwg01 is starting off with a positive reputation.
OK, so how much of each size line do I need to replace all the lines on my Excursion?
And what about the fittings, what do I search for to find those?
  #40
Old 04-08-2016, 02:59 PM
superdave02f552's Avatar
superdave02f552
superdave02f552 is offline
superdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to behold
i used one 25' roll of 1/4" for the rear and one half roll of 3/16 to do the front portions that i didnt buy from ford. up by the abs unit i reused the original fittings and where i could i got them from the parts store
  #41
Old 04-08-2016, 03:37 PM
Snowseeker's Avatar
Snowseeker
All of the nicopp lines I have done are all holding up well yet! Oldest is 3 years on the road now I believe, beat out allot of replaced steel lines already!
  #42
Old 04-09-2016, 07:56 AM
Corndwg01
Got it. Ok, last question - can you bend that NiCop line by hand with no special tools? I'll just need to rent a double flare tool from the Auto Parts store, correct?
  #43
Old 04-09-2016, 08:57 AM
Snowseeker's Avatar
Snowseeker
Yes, very easy to bend and work with as it is nearly half copper. I used no tools to bend up the lines for the last 3 work trucks we have. But when I bend up lines for nice cars I use tools so the bends are uniform and nice.
It also flares easily, cleanly, and seals very well when the fitting is tightened. I have found you don't need to tighten the fittings down nearly as much as steel line to get the joints to seal.
  #44
Old 04-09-2016, 08:59 AM
Snowseeker's Avatar
Snowseeker
I have even used it for fuel lines on our diesels.
volk67
10-29-2017 12:47 PM
flatheadjohn
04-18-2017 06:23 PM
alf15092
12-07-2016 06:13 PM
zweave
Modular V8 (4.6L, 5.4L)
05-22-2016 07:16 PM
honda400ex
54
04-23-2016 02:04 PM
Quick Reply: stupid rotted brake lines
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
