stupid rotted brake lines - Page 2 - Ford Truck Enthusiasts Forums
Old 11-03-2011, 09:47 AM
BassFantasizer's Avatar
BassFantasizer
BassFantasizer is offline
Dirty Old Man in training
BassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputationBassFantasizer has a superb reputation
Originally Posted by airjeff View Post
I hadnt thought of the copper/nickel lines. What are the pro's/con's vs. stainless? It would be much easier to work with. I always think of the copper for water. Where do you find it?
Nevermind, got off my lazy butt and searched. Here is one place:
Federal Hill Trading Company
I'm wayyyyyyy off topic here, but the corrugated copper lines that are common connectors to things like water heaters are fading away. Copper is so expensive that other materials are now being used. I've used corrugated stainless, and plastic/stainless braided lines with good success. That won't help the brake lines, but maybe there's a parallel in there somewhere.
I don't think that I'd want to use copper for a brake line, though....
Old 11-03-2011, 10:14 AM
BassFantasizer
Oh, and this link: Copper.org: Applications: Automotive - Copper-Nickel Automotive Vehicle Brake Tubing suggests that I'm completely off base with my reservations about copper lines. (Note to self -- research, THEN post...)
Old 11-04-2011, 02:20 PM
markland's Avatar
markland
markland is offline
markland is starting off with a positive reputation.
Finally got around to doing mine when I changed out the rear end and to tell ya the truth dreaded that more then anything but it ended up being the easiest part to do. Took the old ends off, which in fact cracked and broke off as soon as I tried to loosen them! To Advanced Auto, matched up both ends on stock pieces they had, got 2 pieces that would make it from the front to back and junction block to connect the 2 in the middle, crawled underneath truck with hand bender and got to work, about 15mins later I was done! Bled out the lines after letting them drip for awhile and works just fine, now I can slam on the breaks when I need to and not worry about whether the line is going to blow!!!
Old 02-09-2012, 07:44 PM
neilc88's Avatar
neilc88
neilc88 is offline
neilc88 is gaining momentum as a positive member of FTE.neilc88 is gaining momentum as a positive member of FTE.
It looks like the brake lines are either 3/16" or 1/4" and both sizes seem to be used on the Excursion. Does anyone know how much of each is required?
Old 08-10-2012, 08:30 PM
sddesigns's Avatar
sddesigns
sddesigns is offline
sddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputationsddesigns has a superb reputation
Buy NiCopp Nickel Copper Alloy Brake Line Coil - 3/16" x 25 CNC-325 at Advance Auto Parts
Buy NiCopp Nickel Copper Alloy Brake Line Coil - 1/4" x 25 CNC-425 at Advance Auto Parts
8' of 3/16" from the connector near the fuel filter to the rear, and 6' of 1/4" for the rear axle with a little to spare.
Old 06-05-2015, 09:18 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
reps to all I can. While researching replacing my rubber brake lines I thought I'd give this a bump..
Old 06-05-2015, 09:42 PM
nowsthetime3.0's Avatar
nowsthetime3.0
nowsthetime3.0 is offline
nowsthetime3.0 is starting off with a positive reputation.
Originally Posted by housedad View Post
1. Buy the brake line from these folks in Atlanta. It never rusts, bends easier than steel, and is fully DOT approved. It is about the best you can get. Copper/nickle alloy. More expensive, but you never have to worry about them again. I am putting this under my truck during this winters upgrades.
2. Get these bending tools as a set. Pretty much does it all.
Tubing Bender and Forming Pliers Kit - Tubing Bender Pliers - Pliers for Tubing
3. Shop around for a double flare tool. The Sears Craftsman and the Ridjid units have a good reputation.
Amazon.com: Ridgid 23332 Flaring Tool: Home Improvement
I have this one and it works real good, but pricy as hell. I figured I would pay less for the tooling and line to put things in myself in one vehicle than I would have to pay a shop to do it. And I get the tools to keep, so I spent the money.
Amazon.com: K-Tool International (KTI70081) Brake Pipe Flaring Tool: Automotive
Careful with the top pliers, lines will kink real easy with them. The tube bender works great, Home depot sells one similar to it.
The Ridgid flaring tool looks better then most auto parts store, made in China pos's. The K-tool is the way to go for decent flairs, I bought mine from Eastwood.
Old 06-05-2015, 10:36 PM
1 Excursion camper's Avatar
1 Excursion camper
1 Excursion camper is offline
1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future1 Excursion camper has a brilliant future
My rear line rusted up near the connector at the framerail next to the engine. I pulled the whole line out in one piece without bending it, and bent up another line using the original tube nuts. the flare on these is a double flare. it went right in with no problems and looks factory. the lines on the axle are still OK, but will be replaced some time this year. the rest of the lines up front are perfect with no signs of rust!
Old 06-05-2015, 10:40 PM
1 Excursion camper
Double post due to website issues!
Old 06-16-2015, 01:04 AM
The2003Excursion's Avatar
The2003Excursion
The2003Excursion is offline
The2003Excursion is a splendid one to beholdThe2003Excursion is a splendid one to beholdThe2003Excursion is a splendid one to beholdThe2003Excursion is a splendid one to beholdThe2003Excursion is a splendid one to beholdThe2003Excursion is a splendid one to beholdThe2003Excursion is a splendid one to behold
Fittings?
What size fittings? Are they sae or metric?
Old 06-21-2015, 01:50 PM
superdave02f552's Avatar
superdave02f552
superdave02f552 is offline
superdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to beholdsuperdave02f552 is a splendid one to behold
Originally Posted by Mark Kovalsky View Post
You can't buy pre-shaped brake lines. You can buy lengths or a bulk roll of brake line. You'll have to make each piece.
actually you can buy almost all the lines from ford with the exception of the one to the right front wheel. it is very spendy mainly for the run to the rear axle because it is part of the fuel line group as well but if the coated brake lines are rotten there the uncoated fuel lines have prolly seen better days
Old 06-21-2015, 01:52 PM
superdave02f552
the 8' near the filter you speak of where is that? there is not any 3/16 for the rear run until it hits the tee on the axle
  #28
Old 06-22-2015, 12:29 PM
1 Excursion camper
The fuel lines are stainless, at least on mine anyway!
  #29
Old 06-22-2015, 01:25 PM
superdave02f552
hey your correct so are mine! so the only thing in the line group to rot is the brake tube and the fuel vent tube (which is in pretty bad shape on mine)
  #30
Old 06-22-2015, 10:59 PM
1 Excursion camper
For the life of me I don`t know why all manuf. don`t put stainless lines in all their cars. It would be safer, and in the end the cost would only be maybe $5 more per vehicle. well worth it to have a safer vehicle on the road.
Quick Reply: stupid rotted brake lines
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
