1956 F100 Crew Cab Project Started - LOTS OF PICTURES
#31
Started rebuilding the doors.
After all ... there are 4!!!!
We replaced the inner and outer panels on both drivers side doors. It seems I forgot to take pictures of the outer skin install... (lots of hammer & dolly action)
I am waiting on My latest Mid Fifty order so we can rebuild the passenger side doors, rebuild the rear leafs, and the master cylinder.
#32
We rolled the truck out to check out the new roof skin.
After striking out with local Sheet metal shops for my drip rail, I headed to my buddies Salvage yard. I was determined to find "donor" drip rail!
He had a 70's Ford Country squire wagon. The wagon had good drip rail on one side, but the other was shot(rotted). I didnt feel safe with only one side, so I kept looking.
I then came apon a 1975 Ford Pinto Woody wagon (lol... decals and fake wood trim). The Pinto Wagon had good drip rail on both sides and the profile looked almost exact!!
I broke out the saws all, and cut the WHOLE roof of the pinto, brought it back to the garage where the crew cab is, and we dismantled the drip rail.
We then fitted the drip rail to the truck.
And recycled some of the roof skin as filler panels. (see the cream material)
#33
#34
Fitted the roof panel to the existing roof area.
We step flanged the forward seam, and cleco'd the panel to the front roof.
Trimmed the excess and radius the corners.
Clecos are your friends.
We removed the roof, trimmed, fitted, trimmed some more, then step flanged the rear of the second cab.
Started spot welding everything together starting at the front.
Then worked around to the back.
#38
Interesting direction you've taken. I hope I'm wrong, but I strongly suspect your flat roof panel is going to warp and oilcan during the welding and/or when you take it outside in the summertime and the sun heats it. The flanged joints are not going to be able to be stretched after welding. I think I would have looked for a panel truck roof or maybe a station wagon if you wanted a flatter profile so it would have had a compound crown to it. There's a good reason vehicles don't have perfectly flat panels.
As you've found and maverikman will find, the drip rails are not just an L or U shaped piece of metal welded to the body, but is a somewhat complex assembly of multiple panel edges spotwelded together inside the gutter (and then covered in sealer) that cannot be simply cut off.
#41
The 56 Crew Cab Show
Tom it looks like you are a experienced body man you make it look to easy.How did you form the roof was it just a flat sheet hand formed in place or did you use the fancy metal shaping tools.How did you mach up the two cabs from looking at mine the back is wider than the front?You should have your truck build put on one of the saturday truck shows keep up the good work.Keep on trucking
#43
We finished welding up the roof and brought it outside to take some more pics.
You can really see the Curve to the roof now.
Well.... I think a 190 pounds of Fabricator guy shows just how strong our roof is!!!!
We accomplished the strength by both curving the new roof skin with the press brake and by the usage of some Dodge Panel truck roof bows from my buddies part truck he was scrapping. radius
#44
While my buddy started mudding the roof I worked on installing the fuel tank. I ended up using the F-28-D fuel tank that seems to be popular with the F100 crowd.
I trimmed 3/8" off the chassis rails, and cut about 1" off the crossmember to get the tank where I needed it.
I then installed a 1-1/2" square tube behind the cut out crossmember to strengthen up the crossmember. I still need to finish the crossmember but it gives you an idea of where im heading.
I did run into a small issue that I didnt remember reading about.
If your running the stock rear suspension and or the rear hangers, your going to have clearance issues with the square tube frame you build for the tank to sit on.
I solved the problem buy suspending the tank with some 1-1/2 x 1/4" straping, front and rear.
