1956 F100 Crew Cab Project Started - LOTS OF PICTURES
#377
Happy Monday, just a little progress update.
I've been agonizing over how to get enough wire to the passenger side of the truck so I can get the fuse pane in an aesthetically pleasing position. My original plan was to blow a huge hole in the inner fender to allow the plugs on the firewall to pass thru this eliminating the run up and down the inner fender.
The more ore I looked at that proposition. The less I liked it.
So I regrouped. Tossed that idea in the trash. And relooked at the placement possibilities for the fuse panel.
After securing the wires with rubber coated clamps.
I was able to route the wires in a way that I could mount the fuse panel in the front corner of the inner fender/radiator support opening.
#382
So I was able also to start mocking up the vintage air ac condenser and dryer.
Of of course I couldn’t find the template to drill the hole for the lines to pass thru the support.
Anyone else not like seeing the dryer dryer behind the grill on our trucks?
im thinking I need to purchase and bend up a new hard line from the condenser and pass it thru the support so I can hide the dryer behind the grill support.
#383
#387
Gotcha. I can’t stand the drier out where it is. So I’m gonna buy some you bend em hard lines and route them thru the wing like the kit and mount the drier behind the wing.
You would think they would offer some alternative mounting options and corresponding pre bent lines. But hey I guess that’s our job to reinvent the wheel.
#388
So today I decided to remove the recently painted lower radiator mount and modify it.
Having not put any thought into mounting hardware for the radiator mount nor the transmission cooler mounting bracket, I fought, sweared and bitched about mounting this bracket to the radiator support hoop.
So, I ground all the paint off. Grabbed some flange bolts and some stacked flat washers for forward spacers. Then welded them to the bracket.
The following users liked this post:
#390
