1956 F100 Crew Cab Project Started - LOTS OF PICTURES
#331
Well gang.... progress continues.
last weekend ended with some hardware painting.
Then it was time to start installing the painted parts.
I started by reinstalling the crank pulley.
Then moved on to the other drive components.
including the water outlet/oil filter housing.
The ac pump, and power steering pump are currently drying. I should be able to install them tomorrow.
The mail man should be bringing me new power steering lines (pressure and return) this coming week. Which will be installed next weekend.
#332
Well it was time to start mocking up the front inner fenders. I decided to cut up my originals before slicing into the new ones I purchased.
The first cuts were close... but not quite.
so another line was laid down.
and yet another cut was made.
bingo!
Then I trimmed off the front and rear tails
and duplicated everything to the drivers side.
bingo!
#333
I've decided to run the crown Victoria radiator.
Way Way Way after deciding to purchase a brand new mid fifty radiator for the ole 272 V8 I was going to run originally.
ohh well... Either I will use it someday of find somebody that wants to purchase it.
Here is the crown vic radiator sitting about where it will end up.
I have to get some plate cut out and start adapting the stock crown vic mounts to the 56 radiator support.
#334
#335
#337
#338
Jules,
I had intended on running the original style radiator. In fact purchased a brand new radiator from mid fifty. However I purchased a radiator for the 272 v8. I cannot bring myself to have that brand new radiator modified.
So I decided to run the crown vic one. I don't think it looks bad. I much prefer the stock look, but dropping another $400 on a radiator is out of the question right now.
#339
#340
AHHHH..... Now I see what you were getting at. I actually sold two original radiators after I purchased my new radiator. But I do like your thoughts.
I was thinking that I might purchase an aluminum oem style radiator off fleabay once the truck is running as a finishing touch. I know I can also get aluminum overflows and power steering tanks for the crown vics and mustangs.
#341
#342
#343
#344
I seen dynamic's work from past threads I think he can knock out both with ease. I always loved the pic when they questioned his roof support of him standing on it. I smile every time I think of it.
#345
