06 f150 problem
Old Oct 12, 2011 | 01:17 PM
Fluke01's Avatar
Fluke01
06 f150 problem
Yes, I only log on when my truck breaks down! I dont have anyone else to ask! I got some excellent help here diagnosing my bad ipr valve on my f250 that was recently stolen. So I picked up a used f150, brought it home and found a problem with it pretty quick.
Maybe this will ring a bell, I did some searches and couldnt find any similar stories.
At low idle, the truck will knock/click, the idle will move around a bit and then it will die. Its happened on the freeway and while in the drive-thru, but only at low idle. It didnt die on the freeway because when I give it gas it picks back up. Most of the time the truck runs fine and its not something I can get to happen, it just randomly happens. The knocking/rattling/shaking (whatever you want to call it) seems to be coming from behind the middle of the dashboard. Any thoughts?
You guys are much appreciated!
Old Oct 12, 2011 | 10:47 PM
air1jpg's Avatar
air1jpg
What engine do you have? Could be airflow sensor.. Any codes?
Old Oct 12, 2011 | 11:02 PM
Fluke01's Avatar
Fluke01
I have the 5.4. No codes. It will stop if I rev up the engine and it doesn't always die. I did a little more reading and I am leaning toward the idle air itake valve, but I didnt get enough info. They said it didn't throw codes.
99StrokeXLT
Aug 24, 2014 08:02 PM
cjgray1974
Aug 1, 2014 07:51 PM
Shernius
1997 - 2003 F150
Oct 27, 2013 06:02 PM
gbrewer
Jul 10, 2013 01:45 AM
brianjw4
13
Jan 10, 2007 10:20 PM
