Anyone running 19.5's on SRW? Tracking issues
Old 09-04-2016, 12:16 PM
WA_PSD's Avatar
WA_PSD
WA_PSD is offline
Just put some on my rig to haul my truck camper more safely since I have close to 7500 lbs on my rear axle loaded up.
They obviously are a bit stiffer and I can deal with that. I air the fronts down to 75 PSI and the rears to 95 PSI, adjust my ranchos down unloaded and such.
My problem is them "tracking". It is a bit uneasy at times loaded and unloaded. It's not super bad, will deal with it and the fact I shouldn't blow out or have a wheel fail is worth it.
I have the Vision Heavy Hauler Type 81's and Roadmaster RM253 245X70X19.5 G.
Any experience or input appreciated. I only have about 400 miles on them and hope maybe they get better as they wear in?
Old 09-04-2016, 06:36 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,180 Likes on 811 Posts
When you mean "tracking" what are you refering to?
Old 09-04-2016, 07:04 PM
Boss73's Avatar
Boss73
Boss73 is offline
I upgraded to vision 81's and Hankook Dh01 265/70/19.5 about a year ago. I am 8k on my rear axle with my camper on, not counting tongue weight of one of the trailers I pull. I had heard that they are a little squirrelly, but I had to have them. They seemed to have gotten a little better over the year I have had them on, but I still notice depending on the road surface. I think they are better loaded than unloaded. I run 84psi all the way around unloaded and put the rears at 95psi when loaded. I probably have only put 2 to 3k on them and love the way they handle with the camper on! Night and day difference!
Old 09-04-2016, 07:11 PM
Boss73's Avatar
Boss73
Boss73 is offline
Trying to show pic from iPad!
Old 09-04-2016, 07:23 PM
crop harvester's Avatar
crop harvester
crop harvester is offline
Is that a 811 Artic Fox ? camper.
Old 09-04-2016, 08:59 PM
Boss73's Avatar
Boss73
Boss73 is offline
Arctic fox 992
Old 09-04-2016, 09:17 PM
Sous's Avatar
Sous
Sous is online now
Received 4,427 Likes on 2,834 Posts
I don't have any insight to the tracking issue, but you guys have some serious weight on those trucks. I thought I was going to be pushing load weight with a 5th wheel hitch of around 3500. That is nothing compared to you guys...
I hope you find an answer to your question soon. The wheels look great.
Old 09-04-2016, 10:12 PM
cps's Avatar
cps
cps is offline
Can`t help you with your question, but I have one. Where did you get your tires and wheels? If you don`t mind me asking. Looking to go the same route I will still be over the door jam rules
Old 09-04-2016, 10:18 PM
Sous's Avatar
Sous
Sous is online now
Wheels can be had here.
https://www.amazon.com/Vision-Heavy-.../dp/B009F9MF82
Tires here...
https://www.amazon.com/Roadmaster-RM.../dp/B00CKQTYQS
These might not be the best prices in town, but now you know what your looking for.
Old 09-04-2016, 10:23 PM
cps's Avatar
cps
cps is offline
Would that be the correct rim size that would fit my truck?
Old 09-04-2016, 10:36 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is online now
I've read in the pass that the 19.5 tires do track going down the road, but you have to trade off for your weight. Guys seem to love that set up with heavy campers and towing. Tracking meaning following the grooves in the road.
Old 09-05-2016, 05:19 AM
WA_PSD's Avatar
WA_PSD
WA_PSD is offline
Thanks for the input guys. I guess it just is what it is. Wondering if it will settle down a hair as they burn in? It really isn't too bad, just a little side to side when in grooves i'm not used to, just enough to get your attention, not throw you into the other lane or nothing.
Old 09-05-2016, 05:26 AM
WA_PSD's Avatar
WA_PSD
WA_PSD is offline
Originally Posted by Boss73
Arctic fox 992
I like the AF 992. Same layout as my Adventurer 910db. Love the rear kitchen and dry bath.
Old 09-05-2016, 07:50 AM
Boss73's Avatar
Boss73
Boss73 is offline
Checked out the link for your Adventurer! Very nice! I really like the U shaped dinette, and the bumper with those steps look great. You'll get used to the way the tires track, I feel it but it is worth it!
Old 09-05-2016, 07:57 AM
WA_PSD's Avatar
WA_PSD
WA_PSD is offline
Like SOUS said, online, lots of options. I paid just under $1700 for wheels and tires, $100 for good locking lug nuts and $200 mounted and balanced, so about $2k out the door. They are stiff and track a little, but you end up with 9k lbs capacity on your rear axle. Wheels and tires are always the limiting factor on these trucks. Most wheels are not rated high enough for this kind of weight and you do not want a wheel failure or tire blow out going 60MPH with over 4ooolbs in the bed of your truck!
Quick Reply: Anyone running 19.5's on SRW? Tracking issues
