Engine Question:(T444E vs. Powerstroke)
Old Oct 10, 2011 | 09:51 PM
ToMang07's Avatar
ToMang07
Question Engine Question:(T444E vs. Powerstroke)
Ok, I *MIGHT* have the opportunity to pick up a cheap International T444E (NOT Powerstroke) engine. It's a 96 with 88k.
SO my thinking.... could I use the block as a donor for forged rods, and put my heads/etc on it?
Is there any incompatibilities? I can't look at it, but I will be out that way in another month.
Thoughts?
Old Oct 10, 2011 | 09:56 PM
BigAlsPSD's Avatar
BigAlsPSD
Here was some information Chris had posted and I saved.
International T 444E Specifications
Old Oct 10, 2011 | 10:04 PM
ToMang07's Avatar
ToMang07
Both engines feature the same specifications; the long blocks are exactly the same between both engines. The 7.3L is simply a T444E in Power Stroke trim.
Guess that answers that!
That's what I thought, but I wanted to be sure. Thanks again!
Old Oct 10, 2011 | 10:44 PM
snakedoc's Avatar
snakedoc
the 96 will have some things that are not the same but can work just fine.
Old Oct 10, 2011 | 10:47 PM
BigAlsPSD's Avatar
BigAlsPSD
True, if it has injectors too, you might be lucky to have some good AC's.
At the heart of the motor though will be the same, front cover, turbo I'm pretty sure are different.
ToMang07's Avatar
ToMang07
Basically, I just want the block. Forged internals. IF I get it I'm just gonna throw it in the garage and store it, anyway. (Once I figure out how to get it out of the bed of my truck.)
It's just a thought. If I can get a forged block for a couple bills.... all the better!
Old Oct 10, 2011 | 11:14 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I think the long blocks are identical for the given year but '96 engines are different then '01 engines. Cranks are different, oil pickup tubes on the other side, front cover etc.
Can you get the engine serial number?
Old Oct 10, 2011 | 11:23 PM
ToMang07's Avatar
ToMang07
No, they don't have it. I'd be putting it in my '02 eventually. I would reallyl ike to get some forged rods w/ Hybrids on it someday. Either way not any time soon, lol.
Old Oct 10, 2011 | 11:36 PM
Shake-N-Bake
It still will probably work fine, you would likely have to use the crank that came with it. You'll want to reuse some stuff from your existing engine. The serial number should be stamped near the oil filter housing. I will try and send you a document that talks about the differences between the various builds.
Old Oct 11, 2011 | 01:08 AM
hotroddsl's Avatar
hotroddsl
The lift pump drive hole in the valley will have to be plugged, I can't remember what size the plug is but it's a easy fix!
Jim & fat Monty
Old Oct 11, 2011 | 10:46 AM
Shake-N-Bake
Thoughts?
Here you go. This is a 17 page document that talks about the short block changes to the 7.3 engine. It's a Ford Technical Training Guide that I downloaded from a link that F350-6 posted a while back. I am taking a leap of faith that the International engines made the same changes since they were built by their Navistar division just like the Ford engines.
I would assume that all International engines have the F650/750 camshafts so you probably want to confirm that for sure. The valve timing is quite different so it's something important to check.
Hope this helps.
File Type: pdf
Old Oct 11, 2011 | 12:10 PM
Brother Les's Avatar
Brother Les
Thoughts?
The '96 is a nonTubo engine. Be very careful as to what you switch out. I have a '91 full shop manuel for that year, gasser and 7.3 Desiel. Nothing seems to match up for my 7.3 2001. So I NEVER use that manuel when working on my 2001 truck. Myself, I would think twice about trusting anything on it.
Old Oct 11, 2011 | 12:35 PM
ToMang07's Avatar
ToMang07
Thanks for the info.
How would a newer T444E fare? What years should I look for? Like I said, If I could pick up a forged block cheap, THAT'S the goal. Not doing anything any time soon. Just a "in the future" kinda thing.
Looks like it's sold, anyway. Oh well. I'll still keep my eyes open, anyway.
Old Oct 11, 2011 | 12:36 PM
Shake-N-Bake
The '96 is a nonTubo engine....
Are you sure about that? Our fleet log shows two trucks from the 1996 model year. They are listed as 4700 T444E trucks. I think the "T" means turbo but I suppose I could be mistaken. Unfortunately both of these trucks operate out of other branches so I can't visually inspect them to confirm.
Old Oct 11, 2011 | 12:54 PM
Brother Les
When it comes to these diesels, it may be hard to be sure on anything.
What I do know For Sure.... is that my 1991 Ford Truck Shop Manuel has every engine that Ford put in their trucks for THAT year. It had the 7.3 SIZE diesel, with ALL the information on it. That year of 1991 is not Tuboed by My Manuels. Remember, the 'Family' of engine that we run is from 1999 to 2003.....
Looking on the Forum list Pre 1994.5 is Pre PowerStroke with a range of 1994.5 to 1997 of the 7.3 Powerstrke with a gap of 1997to 1999.
I would suggest going to the 1994.5 to 1997 and ask them what they also think would be able to be transferable.
Bottom line, get all the info you can before you start changing out parts.
